Sponsored by:
Sponsored by: CARiD
Immobilizer question for 3.5 swap
Old Aug 27, 2007 | 11:57 AM
Red Lion's Avatar
Searched. I'm doing a full 3.5 ECU/harness/etc swap so of course I'll need the ignition switch with immobilizer. But, I'd really prefer to keep the switch I have now so that I can have a new key cut to match my car (and programmed to match the ECU of course).
I've haven't seen a good pic of the immobilizer setup, but I have seen the immobilizer sold independently of the ignition switch on some sites. My question is this: can I buy the immobilizer and just attach it to my current ignition switch? Will it come with the necessary wiring parts? Looking at some pics it looks like just a ring and a sensor, but I can't tell for sure.
Old Aug 27, 2007 | 12:17 PM
nismology's Avatar
The ignition switch and immobilizer system are completely seperate. All that matters is that the NATS IMMU needs to have a programmed key in very close proximity to it, wherever you decide to mount it.
Yes, you can buy it seperately and mount it anywhere but it won't come with any wiring.
Old Aug 27, 2007 | 12:28 PM
DasYears
you should get it from the same car you got your ecu from, and then just attatch the key/chip under the steering wheel/dash somewhere close to the unit.
Old Aug 27, 2007 | 12:48 PM
Red Lion's Avatar
Thank you very much!
I read some people did that and it worked, I might do that.
That's all I need, thanks you guys!
Old Aug 27, 2007 | 05:26 PM
nismology's Avatar
In case you can't get your hands on the proper wiring harness, the NATS IMMU only has 5 wire connections. Constant (15A fused) battery power, Ignition switch On or Start switched (15A fused) battery power, output to Security indicator LED, output to ECU, and ground. Pretty simple to wire up.
Old Aug 27, 2007 | 05:39 PM
Red Lion's Avatar
hmmm, is there nothing coming off the dash harness that connects to it? I figured the dash harness would have the connection for it. I have a complete harness I'm going to cut and work with.
Old Aug 27, 2007 | 05:41 PM
DasYears
i believe in the immo cars that there is a 5-pin connector which supplies those 5 wires.
Old Aug 27, 2007 | 05:47 PM
nismology's Avatar
Yes the main (dash) harness has a connector for it. Good deal.
I<3 A32's
Sep 10, 2015 11:07 AM
MaxLife17
Sep 8, 2015 02:36 PM
JoshG
Sep 5, 2015 10:10 PM
Maxboy23
Sep 4, 2015 06:04 PM
Johnny9595
Sep 3, 2015 05:18 AM
