Sponsored by:
Sponsored by: CARiD
OOvi
Old Sep 8, 2007 | 09:56 PM
asperos28's Avatar
OOvi
Ive herd you can put the 5th gen oovi manifold bolted to the 4th gen lower?
is that true first of all? and if it is what parts do i need besides a rpm switch and the 5 gen tb?
Old Sep 8, 2007 | 10:10 PM
96blkonblkse's Avatar
There are tons of FAQ's on this man. But im a nice guy so ill list it:
Yes you can use the 00vi on the 4th gen.
http://away.no-ip.org/maxima/
hmmm seems tatanko's site is down. He had everything on the 00vi swap.
basically the easiest way is to use:
4th gen lower intake manifold
send it to stephenmax get it redrilled for the 5th gen upper
you will need all the necessary gaskets
5th gen TB or 4th gen TB
IACV block off and use the 4th gen
rpm switch
you need to use either the 5th gen valve cover and 5th gen coilpacks
or 4th gen valve cover, grind down 1 of the coil pack bosses and only use 1 bolt.
5th gen egr guide tube
i think thats all, its not an extremely complicated swap, most of it is bolt on, no real custom work involved other then the LIM and iacv. which you buy premade.
if you use the 5th gen lower, you have to use the 5th gen injectors and then you gotta re-wire your injectors, you need the 5th gen clips, you need to get some additional fuel related fittings.
You will need to get it tuned though, the 5th gen injectors are bigger.
i think i pretty much answered all your questions..check out tatanko's site for more info hes got ALLL the 00vi swap stuff on there.
Old Sep 8, 2007 | 10:51 PM
Tatanko's Avatar
Bacon Lover
Yeah, I apologize that my site is down. I have all the files, but my original host sort of backed out on me, so until I can find a new host it's down.
To the OP, if you'd like, I can send you some of the info if you want it.
Old Sep 8, 2007 | 10:53 PM
NmexMAX's Avatar
dot dot dot ...
Don't we have a sticky for this?
Old Sep 8, 2007 | 10:56 PM
XJinCT's Avatar
<3's the all motor section
wait. i didnt even know you could do this. thanks for the information.
Old Sep 9, 2007 | 12:04 AM
spdfreak's Avatar
This might sound funny, but even I knew this. There are alot of faq's on this.
Old Sep 9, 2007 | 08:56 AM
asperos28's Avatar
thanx ive had this thing sitting at my house forever and i want to put it on
bksmax11203
Nov 7, 2012 06:01 PM
rizzindriver89
Aug 18, 2010 10:23 AM
96nismomaxi
Nov 13, 2005 06:39 PM
VQ30de96
Oct 6, 2005 08:35 AM
