Tranny Lines to Radiator
Old Aug 12, 2001 | 05:29 PM
BMaxin '91's Avatar
I recently changed the radiator on my '91 SE and there are lines from the tranny to the radiator. Is this supposed to provide some sort of cooling? I've read prior threads suggesting a tranny cooler, what do you use to plug these outlets on the radiator if you do add a tranny cooler?
Old Aug 12, 2001 | 06:10 PM
Brian_TII's Avatar
Typically you use this AND a tranny cooler. You simply run the tranny cooler off the return line from the radiator. If you want to TOTALLY eliminate the radiator (don't see why you would unless you had a previous tranny let go) then you don't need to do anything to plug them up, they don't have fluid running though them unless you have them hooked up. (Coolant and tranny fluid DON'T mix in there :-) )
Brian
87 RX-7 Turbo II
89 Maxima (daily)
Old Aug 13, 2001 | 03:32 PM
CandiMan's Avatar
Say Candyman 5 times
Exactly
Those who are using an auxillary cooler are also using their OEM radiator cooler. As Brain mentioned you just install the after-market cooler in the return line going back to tranny. When you open your hood and look down at the two lines, the return line is the one on "your" right. You can check the stickies at the beginning for any other possible questions you might have.
Old Aug 13, 2001 | 05:47 PM
BMaxin '91's Avatar
Re: Exactly
Thanks for the info guys.
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
