WIll fuel Injectors from a VE work well with a VG?
Old Aug 14, 2001 | 04:47 AM
BeatJunky's Avatar
Looks like I will be getting a set of used fuel injectors from a 92 SE for my 90 Maxima... Will this work fine or will I end up having some spare parts?
-Beat
Old Aug 14, 2001 | 08:55 AM
MaximaSE91
do not use the fuel injectors out of a 92 se the connectors wont work im pretty sure fuel injectors from a VE have a red top and fuel injecotrs frma VG have a pink top and different connector.
Old Aug 14, 2001 | 09:24 AM
BeatJunky's Avatar
How sure are you?
Old Aug 14, 2001 | 02:15 PM
Chris Gregg's Avatar
Get Off My Lawn
Better check to make sure they are the same ohms too.
Old Aug 14, 2001 | 02:20 PM
Jeff92se's Avatar
I'm needing a caw
I *think* the VG injectors are feed via rubber hose while the VE injectors are feed directly through the solid fuel line(ie.. side feed). I don't think ve ones are going to work even if the electrical connectors are the same. It's the physical installation that worries me.
Old Aug 14, 2001 | 05:11 PM
MaximaSE91
no they are fed exactly the same
the connector on the injector harness is just different and the resistance in the injector coil could be different also
kjlouis
Nov 24, 2018 06:09 AM
Cotozic
Jun 28, 2017 08:01 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
Balkins
Aug 12, 2015 06:39 AM
kenc15
Aug 5, 2015 08:29 AM
