0707 and 0304 sensors
I recently changed my two o2 sensors in the front and now a month later i'm getting 0707 for the rear 02 sensor I reseted the ECU and the check engine light came back after I filled up the car with gas I then did the self diagnostic with ECU then I got 0707 and 0304 which is the knock sensor. If I change the 0707 will the 0304 code go away or do I need to do both?
THANKZ ALOT
THANKZ ALOT
THANKZ ALOT
THANKZ ALOT
- model year
- transmission
- odometer reading
- mods (if any)
- recent repair history
- a detailed report of symptoms
I suggest you replace the rear Oxygen Sensor and reset the Engine Control Module. That one repair may resolve both codes.
Thankz for the quick reply DBM but should I go with the nissan rear 02 sensor or can I use the after market sensor.
Read the first post in the Sticky 4th Gen Maxima Maintenance. You will see contact information for dealers who sell genuine Nissan parts at a discount. You may be able to get a Nissan sensor for the same money as an aftermarket item.
TallTom
57
Oct 14, 2025 05:16 PM
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
