better grip on a '00gle
How can I get better grip from the stock 16in rim/tire setup. I can step on the gas and burn out and around turns the front pulls out. (I'm used to understeer) now besides telling me to drive slower (I really don't drive that fast. honest) how else can I get better drip?
You could probably burnout a set a pirelli's in about 1yr with the way you describe it.
Dixit
RSB? by adding that to my rear will cause more of a understeer (rear swings out before the front?)
that would be adding oversteer. You will get more neutral handling with the RSB
Right, I had that backwards. So what youre saying is I would still loose grip at about the same speed as without the RSB, but instead of the front sliding outward first, the whole car tends to slide?
Fine-tune the feel by playing with tire pressures. For handling, you typically want a little more air in the front tires than in the rear ones. Without a RSB, maybe 5 or 6 more psi up front than in back. When you add a RSB, you'll probably need to add some air to the rear tires to keep it from feeling "loose", so they'll be maybe only 3 or 4 psi less than the fronts.
Norm
may i recommend just the basic? new tires...these are similar to the s2000 tires if not better. from what i hear these tires have better reviews, because of better treadwear.Bridgestone Potenza S-03 Pole Position.
or your can try a cheaper tire that gives probally equally the same or better... Kumho Ecstas 712s.
