17" Tire Size?
Old Aug 23, 2001 | 08:25 PM
Bob_Jaap
I'm getting ready to replace the pathetic Bridesone RE92s on my Maxima. The recent downpours of rain here in the Pacific Northwest have made the roads quite slippery for the stock tires.
My question is: Will a 245/45-17 tire fit without rubbing on anything. If this size works I will probably also get some new 17" x 8" rims. The Tire Rack says the largest tire that will fit without rubbing is a 235/45-17. Anyone tried the 245s?
Will the 235s fit on my stock 17" x 7" rims?
I'm considering the Yokohama Db ($144 in the 235 and 245), Dunlop SP5000 ($129 for the 235 and $134 for the 245), and the Goodyear HP Ultra Plus ($113 for 235 and $145 for the 245). Any comments on these tires?
Prices are from The Tire Racks latest add.
Thanks.
Old Aug 23, 2001 | 08:29 PM
Greg's2kGLE's Avatar
Thanks.
Check the FAQ. Someone did try putting 245's on the stock 17's, I think they said they fit with no problems, but in the long run, who knows. Try the search feature.
Old Aug 23, 2001 | 08:39 PM
MS 2K1 AE's Avatar
Thanks.
Do a search on this, there is plenty of content on the board to answer the question. But to save you a little time (the search leaves a little to be desired), the 245/45 can be put on the stock 17 x 7 rim and won't rub (some members here run that way). Key word is can...none of the tire manufactures recommends it however. 235/45s aren't even recommended on our 7"ers, but many more run that config.
Bottom line, if you can swing the extra bucks for 8" rims and 245/45 (closer to stock diameter than the 235/45s), then go for it. This has it's drawbacks though...heavier rims (usually) and increased rolloing resistance due to the larger contact patch (this could slow you up a little)
In the 225/50 the choices are few and far between. BTW, the Yoko db's are great tires. My upgrade will be 235/45 Yokos or Kuhmos on my standard 7" rims.
Old Aug 23, 2001 | 08:45 PM
Weasel's Avatar
Wait til y2kse finds this thread...
The consensus is that it's possible, but you're taking your safety in your own hands. If the tire fails because it's too wide for the rim, the manufacturer will not do anything about it. The maximum recommended tire width for a 7" rim is 225. What you do with your own car is your business, but don't expect the manufacturer to be held responsible if the width causes any problems.
Old Aug 23, 2001 | 09:07 PM
Bob_Jaap
I'm trying to stay within the mfg. spec for tire vs rim width. Also, I don't care for the look of a tire that is squeezed onto an undersized rim.
Anyone interested in purchasing some stock 17" rims? :-) I just found a cheaper price on the dunlps at Discount Tire ($120 for 235s and $131 for 245s).
Old Aug 23, 2001 | 11:30 PM
BigDogJonx's Avatar
I dont think you wanna go 245/45/17, you should go 245/40/17. Because that way you will keep the outer diamter almost the same. 245/45/17 will be a larger diameter than a 235/45/17. That will throw off the speedo and will make it look like there are larger than normal tires on your car.
But I know for a fact that a the 245/45/17 will fit because I had them on my Millenia S and swapped the rims for a week and they did not rub at all.
Dixit.
Miket2006
Mar 1, 2021 03:55 AM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
knight_yyz
Nov 1, 2015 01:34 PM
Garrettz459
Sep 28, 2015 02:50 PM
