oil change-do it yourself?
I just purchased my first Maxima (01 GXE/5spd)and it drives like a dream. (Of course I am comparing it to my 1982 Datsun King Cab 5spd pickup!)Seriously it really is a nice car. I have always changed my own oil and would not trust this car to one of the quick change places. It appears as if the filter is difficult to get to. Somewhere in one of the forums I read where it really wasn't all that hard and that one could do it without even crawling underneath the car. Any tips on doing this?
Thanks from a first time Maxima owner
Let me just say that if I can do this, anybody can. Good luck and welcome to the family.
Re: ...
Originally posted by TimW
I've never crawled under the car. I've removed the right wheel, but thats about all. that alone will make all the difference.
Thanks for the pointer about removing the right wheel and not having to get under the car.
Damn...king cab? My dad had one...blue...diesel took forever to start on cold mornings...dropped in cod liver oil once in a while.
anyways...if you plan on doing your own oil change, keep receipts, write down date and odometer. You need to keep things documented so the dealer won't screw you over when you need your warantee to kick in.
Jay
Jay
I just changed my oil for the first time last week as well. Personally I use ramps just because I like to be able to see what's going on under there when I'm working on it. I didn't remove the panel that covers the filter, I just pushed it out of the way when removing the filter.
My one gripe is with the guys at assembly. They are just like the guys that work at the quickee lubes. I guess they all think the filter has to be installed with 100 ft lbs of torque! Since I didn't have a filter wrench small enough to remove the ultra-tiny filter I had to drive a pin punch through it just to get enough torque on it to remove it!
Sorry for the rant, I just get so frustrated with people who think oil filters need to be installed with a 5 ft. pipe wrench! There's a reason the filters say "Install filter until gasket contacts base, then tighten 3/4 turn". That's all the tighter it needs to be! I've done it like that for 100's of oil changes without a single leak.
changing oil
Re: changing oil
It's not necessary to use ramps, remove the wheel, or take off the panel. You might find that steering the wheels a little gives a bit more room.
Apparently there isn't a dedicated wrench commercially available for that tiny-diameter filter that Nissan uses. I ended up modifying a metal-band universal filter wrench (that I bought when I had my '87 Max) to grip the miserable little thing.
Norm
Norm
Re: Re: changing oil
Doesn't matter to me anyway, I don't need a wrench anymore!
This is how I do it. I had a hydraulic floor jack, so you'll need this. First remove the filler cap and dip stick so the oil will run out freely. Then jack up the right front with the hydraulic jack untill the right front tire is about 1 inch off the ground. I then use the trunk mounted jack for the car as a back up and place it next to the floor jack and snug up the screw jack so there is no way the car is going to fall on me.
Next you'll need (beside the box wrentch for the drain plug) a filter (strap) wrentch which has an adjustable handle. Without this, taking off the filter may be impossible. So first I drain the oil into a pan. Then with your left hand pull the plastic shroud down to gain access to the oil filter. This is when you'll appreciate the adjustable handle on the strap wrentch. Remove the oil filter under the drain pan and replace the oil filter and plug and your done with the fun stuff.
I find 4 quarts even fills my engine to the full mark on the dip stick, so I don't bother with the 1/4 quart the manual says. I'm done in less than 30 minutes.
Originally posted by mike-777
. . . I find 4 quarts even fills my engine to the full mark on the dip stick, so I don't bother with the 1/4 quart the manual says. I'm done in less than 30 minutes.
Norm
litch
123
Jan 4, 2024 07:01 PM
05RLS2
Apr 14, 2016 11:49 AM
