fuel pump supports how much hp??
hey
was wondering if anyone knows how much hp the Walbro fuel pump is suppose to be able to support? does Walbro have a website? thanks....
300zx pump, please! Its not a direct replacment in a 4th gen, the walbro is. Not to mention that the 300tt pump is twice as much new.
@12v's and 40psi the walbro 255lph "high pressure" pump will flow 59gph, thus supporting 708hp, at 13.5v's the flow goes up to 68gph, thus supporting 816hp.
The rule of thumb is 1/12gph per hp.
Your stock fuel lines will need to be replaced before the walbo 255lph HP reaches its full potential.
Turbo look at this to see how it performs at your aplications pressure level.
Pressure....."high pressure"
(psi).....255 ltr/hr pump GPH
0.........75
10........72
20........68
30........64
40........60
50........56
60........52
70........49
80........44
90........37
100.......27
110.......13
HP......Gph Needed
190.....15.83
220.....18.33
250.....20.83
250.....20.83
260.....21.67
270.....22.50
280.....23.33
290.....24.17
300.....25.00
310.....25.83
320.....26.67
330.....27.50
340.....28.33
350.....29.17
400.....33.33
450.....37.50
500.....41.67
550.....45.83
600.....50.00
650.....54.17
Look her for some good info
http://members.home.com/syclone/APE/
0.........75
10........72
20........68
30........64
40........60
50........56
60........52
70........49
80........44
90........37
100.......27
110.......13
HP......Gph Needed
190.....15.83
220.....18.33
250.....20.83
250.....20.83
260.....21.67
270.....22.50
280.....23.33
290.....24.17
300.....25.00
310.....25.83
320.....26.67
330.....27.50
340.....28.33
350.....29.17
400.....33.33
450.....37.50
500.....41.67
550.....45.83
600.....50.00
650.....54.17
Interesting alright... but what about the injectors? What is a direct drop in injector that can pump out that much fuel? Anything else in the fuel rail need to be changed? I guess the pressure regulator also needs to be changed too but those are pretty universal.
But remember changing the injectors will also require you to get your ECU upgraded and mapped for that extra fuel, otherwise you will not be going anywhere. And for the ECU upgrade you must either have a 95 Max or some 96's, so that leave many of us without the option to upgrade injectors.
I'm no expert, but.......
I think when most of the turbo Eclipse guys upgrade to 550cc injectors they can use the Super AFC to "recalibrate" on the stock ECU without any major ECU reamapping(basically what Sith was saying)...I'm not sure how that would apply to the Maxima, but I'm just guessing.....my friend is planning to go this route on his GST eventually(too bad hes a damn slacker when it comes to mods
from the article:
"The biggest use for the AFC is to install larger injectors (richer) and then adjust the AFC leaner to compensate. This also raises the point where you hit fuel cut since the ECU sees less air flow (lower frequency Hz)."
rest of it--> http://www.roadraceengineering.com/newafc.htm
any ideas guys???
)from the article:
any ideas guys???
thanks MardisGras,
i have an SX pump rite now. do you know how i can find out the specs on that? also, my electronic fuel press gauge no work anymore.....do you know how can i check the sender unit? its 3 wire.
oh, what we do for friends/customers and alot of people do as well is with larger injectors you basically lean it out on idle so you dont run too rich. You need to tune all this crap. I heard from few people that the AFC doesnt work for the Max....
Originally posted by Turbo95Max
thanks MardisGras,
thanks MardisGras,
This guy had one running on his Max. Seemed to work fine.
thanks MardisGras,
thanks MardisGras,
Originally posted by SithMax
http://forums.maxima.org/showthread....threadid=62449
I have one as well but I have not bothered tuning it till I add a few more mods, then Dyno here I come
jmlee44
Oct 2, 2022 02:13 PM
