Help - Oil Leak
Old Sep 3, 2001 | 10:48 AM
maximaman69's Avatar
Ok, Nissan is closed until Tuesday and with my work schedule next week, it's going to be tough to see them but I have a question for you guys.
My car is 4 months old, new, 2001 SE. I have an oil leak that just started like Thursday of last week. In about 3 hours, it leaves about a half-dollar size mark on the ground and typically only happens after I have driven it. If it's just sitting there for a day it doesn't happen.
What could be causing this? I'm majorly PO'd at the fact my car is only 4 months old and has an oil leak. Oil was changed two - three weeks ago but didn't see this problem until late last week so I don't think it's an oil change issue.
Anyone else ever have this problem?
Old Sep 3, 2001 | 11:15 AM
got rice?'s Avatar
find where the oil is leaking from; there are numerous places where a leak can occur - cam seals, crank seal, oil filter, valve cover, etc.
Old Sep 3, 2001 | 11:35 AM
Paul6speed's Avatar
Are you sure the oil change is not related to the leak? Check the oil filter and oil drain plug for a tight seal. Oil leaks are very rare on the Maxima.
Old Sep 3, 2001 | 01:17 PM
BigDogJonx's Avatar
Check under the car, I have a feeling it is either the drain plug that is not on Tight or the Oil Filter was not put on tight.
It can easily leak when the oil is hot because it is thinner and flows better, when oil is colder, it is typically a little thicker and that is why it may not be leaking when it just sits there for days.
That would be my best guess.
Dixit
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
