Installing Koni's???????
ok guys....my konis will be arriving in a few days.....and since they are inserts......how hard are they to install....are just the fronts inserts...or all of them?....any info will be appreciated......thanks in advance
Originally posted by SprintMax
http://www.performanceix.com/how-to/...print_koni.asp
THANKS!!!!!!!!
Drilling the hole is pretty easy. And the hardware provided is perfect--just make sure you use it all. Also, since there is the question of the bolt holding the insert down possibly coming loose in quick order, you might want to consider putting some Loctite on the threads.
ya.good idea......
