Remote for alarm !
Re: Remote for alarm !
Originally posted by asianpr3082
Hey does anyone know how to program the remotes to the car ? If you can help me it would be cool thanks
Q: How do I reprogram the Keyless Remote?
A: Here's the procedure from the 1995 Factory Shop Manual
Replacing Remote Controller or Multi-Remote Control Unit (LCU05)
Enter the identity (ID) code manually when:
remote controller or multi-remote control unit LCU05 is replaced.
an additional remote controller is activated.
ID Code Entry Procedure
To enter the ID code, follow this procedure.
Entering "Setting mode":
(1) Close and lock all doors.
(2) Insert and remove the key from the ignition more than six times within 10 seconds. (The hazard warning lamp will then flash twice.) At this time, the original ID codes are eliminated.
ID code entry:
(3) Turn ignition key to "ACC" position.
(4) Push lock button on the new remote controller once (for example, if door is locked using the remote controller during this ID code entry enable state, a new ID code can be entered). At this time, the new ID code is entered. (The hazard warning lamp will then flash twice.)
Additional ID code entry
(5) If you need to activate additional remote controllers, unlock the driver's door, then lock again with door lock ****.
(6) Push lock button on the additional new remote controller once.
(7) This ID code entry enable state and setting mode remain until the driver's door is opened.
NOTE
If you need to activate more than two additional new remote controllers, repeat the procedure "Additional ID code entry" for each new remote controller.
If the same ID code that exists in the memory is input, the hazard warning lamps will flash twice but the entry will be ignored.
Entry of maximum four ID codes is allowed and any attempt to enter more will be ignored.
Any ID codes entered after termination of the "setting mode" will not be accepted. Additionally remote control signals will be inhibited when an ID code has not been entered during the "setting" mode.
ID code entry:
NOTE
i had a humoriss experience with one.. i later found out that before programing you must make sure when your key is in the ignition and in the on postion you must have a ornge security light.. then you take your key out... and shut the door.. put in and take out the key 10 times i think (no this isnt a joke i did it with my dads car) then you press the arm button.... if you have any trouble with it take it to the service dept. they will do it for free.
later
Re: Re: Remote for alarm !
later
later
ToTheMax305
Sep 23, 2015 09:11 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
