taking out back seats.
4 bolts?
Ok, here's how to do it. In front of the rear seat there's gonna be two tabs, one on either side. Pull up on the tabs and pull up on the seat (the portion you park your *** on). This should lift right out. Next, there's one 10mm bolt on each lower corner of the backrest. remove this and lift up the backrest. Lift it straight up to get it out of the holders (hard to describe, you'll see what i'm talking about) That should be it. Installation is the reverse.
Chris
Chris
Once again here it is:
A very helpful link- it gives the directions in the stereo install section
http://www.geocities.com/artourb/max...hoto_album.htm
Eh?
There's another two bolts (making 4 total, so if you've removed the right ones, you shouldn't have much problems taking it out) located at the arm rest.
Remove the little flap/cover on the trunkside of the armrest, and remove the two 10mm bolts there. Do the other ones CKNY said, and then it should lift right out. I found I couldn't lift it right out, and had to lift it a little bit on each side before I could get it to pop off.
There's 6 bolts total! There are two or the bottom corners, two that are closer to the center on the bottom, like in the middle of where a person would sit on each side, and two behind the armrest.
Finkle
Sep 27, 2015 09:53 PM
ramtin325i
Aug 8, 2015 05:13 PM
