Clutch pedal saftey switch???
no idea, but on the 5.5 gens w/6mt you have to push the key in, it's pretty snazzy.
It's not that bad, there is specifications in the fsm, the symptoms would be starting related..........
clutch pedal has no tension!!
alright then, new clutch problem:
my clutch pedal has no tension whatsoever, it just hangs slack down near the floor. when i parked it yesterday it drove fine; today, its all slack and i cant get it in gear. is it possible the clutch cable popped off or something? is this 'clutch gone bad'? it is a 98SE5sp with ~119K on original clutch. i've been waiting for it to go out any time now, but it has been driving fine until today. just seems pretty sudden and wierd. hasnt had any clutch fade or anything.
Normally a threadjack isn't cool either, but I geuss it's somewhat related and who cares with this guy now anyways
Free google search does wonders, this has happened many times. Check ur fluid level, reservoir is on the firewall below/to the right of the brake booster, probably a leak in the lower clutch line. More than likely a hydraulic failure of some sorts, the maxima clutch has no cable.
ive also had that problem
Its probably a 95% chance its low clutch fluid ive heard that its common for the line i believe lower to leak.............But is there anyone that knows how to check or change the ignition cause this seems to be my problem at hand????
could b the clutch slave cylinder... but check the pressure hose first... i replaced my clutch slave cylinder first which only solved the problem for a few hours... than i replaced the pressure hose... and than i joined maxima.org and found out that i should've checked the pressure hose first because its common.
HerpDerp1919
Sep 29, 2015 02:02 PM
