New Springs
New Springs
Well I finally got some new front springs in, same drop as before but as soon as I was finished everything was great except now my allignment is slightly off, pulling to the right. I'm also replacing the tie rod end tommorow as well but the allignment was fine untill the new springs. Is that a normal occurance since the spring was broken for so long or is there something I should check.
If you had to remove the strut then your alignment should be off. IIRC you can paint a circle around where those two 17mm bolts go so you can keep your alignment but I'm not sure, Lets wait and see if anyone with more experience chimes in.
Toe-in is the only adjustment that can be made on these cars,the toe is adjusted at the tie rod end.
Then why did I have to get an alignment after replacing struts? I dont have any aftermarket bolts
If you look at FA-6 of your FSM,it will tell you exactly what i said in my first post,toe-in is the only adjustment.
MaxLvr21
Oct 17, 2015 12:11 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
followthadollar
Sep 27, 2015 01:06 PM
