Quicker cure 4 check engine light!
Old Oct 1, 2007 | 10:24 AM
BMWHIGH1's Avatar
Well after I realize that there is nothing wrong with my car that will put my life in danger (which I know is stupid of me to assume). Yes, i know the reason i keep getting the check engine light. I think I may have found away to turn off the check engine light without re-setting the computer, but it doesn't last long, maybe about 2-3 weeks or depending on mileage you drive I have not quit figured it out yet. After I got so upset with looking at the check engine light, one day I just sat in my car and turn the key from the off position to the on position (but Not starting the car) about 3-5 times I Don't know where that idea came from maybe from the Maxima Gods , but within I guess 24 hours with the car off there should be no check engine light when you start it back up!, I have done it about 3 times already since my check engine light came on about three months ago. I don't know if this will work for everyone, I don't know the side effects from it but nothing has happen to my car yet! So I hope this helps for some of you with the check engine. I just hate when I have people in the car and they say oh, your check engine light is on, and I say to myself Yeah like I didn't see the orange light burning a hole in my face! Good luck! Let me know if this works for anyone or if anyone has done this before
Old Oct 1, 2007 | 10:31 AM
tonyw's Avatar
Why not go to Autozone where they'll scan it and tell you what's wrong free?
At least you'll know why it's on and then you can decide to ignore it or not..
Old Oct 1, 2007 | 10:43 AM
mtrai760's Avatar
'Trynna' is not a word
takes about 2 seconds to check with a scanner from a major autoparts store like autozone, and you can reset the codes at the same time.
Old Oct 1, 2007 | 10:49 AM
NmexMAX's Avatar
dot dot dot ...
No, That's just too logical IMO, I would rather do as the OP suggested and just hope it (SES light) doesn't return.
Old Oct 1, 2007 | 11:16 AM
HotMaxx02's Avatar
Or you can permanently fix it... Take out the Bulb
Old Oct 1, 2007 | 11:31 AM
BMWHIGH1's Avatar
I know what the problem is i wasnt asking for help i was giving a quick solution for a problem like for guys who know whats wrong with there car maybe because of headers or an exhaust system or whatever for whatever reason you have a check engine light. i know what the problem is i just dont want to fix it right now!
Old Oct 1, 2007 | 11:38 AM
BMWHIGH1's Avatar
Thats why i started the thread because i know whats wrong and I'm going to ignore it right now! Thank you!
Old Oct 1, 2007 | 11:41 AM
mtrai760's Avatar
You gave a lousy solution, there are much easier, and better ways, don't get mad.
Old Oct 1, 2007 | 12:28 PM
Kyle00's Avatar
WSH for teh cup
Clear it with a code scanner. A very easy way to clear a code like the others have said. And your method..... Who knows if it even clears the code, sometimes the SES light can be off but the code is still stored in the computer. So the best bet would be the traditional way of clearing it with a scanner
Old Oct 1, 2007 | 12:32 PM
pakistunna786's Avatar
mine is on too, for about 6 months now. i was told it was the ignition coil and that obviously didnt work. also tried mass air flow sensor, no good
Old Oct 1, 2007 | 12:36 PM
HotMaxx02's Avatar
mee too... I just dont feel like fixing it right now. Thanks for the input, i agree.
Good Looking out
Old Oct 1, 2007 | 12:38 PM
i also hav the airbag light on, but it goes off by itself occassionally. weird
Old Oct 1, 2007 | 12:39 PM
Kyle00's Avatar
WSH for teh cup
Stop hijacking the thread and go post in the Noobie thread
Old Oct 1, 2007 | 12:47 PM
for some reason i cant make my own post it says
Old Oct 1, 2007 | 12:51 PM
BMWHIGH1's Avatar
Good Looking out
Thank you finally someone who understands!
Old Oct 1, 2007 | 02:14 PM
GETukrainian's Avatar
it's cuz you're a noob, get 15 posts before you can make your own post
back on topic:
this is better than my fix, i just have a piece of black electric tape blokcing the SES light (just like the OP, I know what's wrong with my car and it keeps coming back after being reset, and I'm too lazy/poor to fix it right now)
Old Oct 2, 2007 | 05:11 AM
KRRZ350's Avatar
Well he knew what the problem was, he was just being informative and telling us an easy way to reset the light, that's good to know imho. In mass autozone isn't allowed to reset the cel anymore, and they're pretty strict about it.
Old Oct 2, 2007 | 07:17 AM
aksansai's Avatar
01 Maxima SE, 5-spd
Has anyone else tried this?
Old Oct 2, 2007 | 07:36 AM
NmexMAX's Avatar
dot dot dot ...
My light comes on after the 2nd time I start the car after it has been reset. Not much gained for me there .
Old Oct 2, 2007 | 07:45 AM
BMWHIGH1's Avatar
Well i did say let it sit overnight first, i always do it when i come home and i know i'm not going out until the next day . If it doesnt work for you maybe your car has a much more serious problem than mine
Old Oct 2, 2007 | 07:52 AM
Czerkas's Avatar
mine has worked ... for a while now
Old Oct 2, 2007 | 08:07 AM
BMWHIGH1's Avatar
Did you try it the way i did it?
Old Oct 2, 2007 | 08:11 AM
Czerkas's Avatar
ya .. i did it yesterday after work ... started my car three times since then and the light is gone for now
NmexMAX's Avatar
dot dot dot ...
Regardless of how many nights my car sits, the light WILL return after the 2nd start-up.
http://forums.maxima.org/showthread....es#post4270440
Old Oct 2, 2007 | 08:21 AM
sontakke's Avatar
Is $36 too much for a cheap scanner for you? Why bother making trip to Autozone if you have to do it often? If you google or ebay, you should be able to find very cheap scanner which can read and erase codes.
I keep a scanner in one of my vehicles which keeps on tripping the infamous P0420 Catalytic Converter Efficiency Low code regularly.
- Vikas
Old Oct 2, 2007 | 08:27 AM
NmexMAX's Avatar
dot dot dot ...
- Vikas
www.uprev.com
Old Oct 2, 2007 | 08:43 AM
SoonerFan's Avatar
Cletus
if you dont care whats causing the problem, why do you care if the lights on
if you are gonna ignore the problem...just ignore the light
Old Oct 2, 2007 | 08:53 AM
vq35's Avatar
my ses and battery an brake light wont go off...an th alternator is good?
Old Oct 2, 2007 | 09:11 AM
machinehead131's Avatar
get the damn code pulled and fix the problem
Old Oct 2, 2007 | 03:21 PM
BMWHIGH1's Avatar
Sorry about that maybe it does not work for you are you a 5thgen or 5.5?
Old Oct 2, 2007 | 03:23 PM
BMWHIGH1's Avatar
- Vikas
Because I dont want to, look dude it was just a suggestion okay! I know my options I choose not to do it!
BMWHIGH1's Avatar
Because i dont want the light in my face re-read the thread buddy
Old Oct 2, 2007 | 03:30 PM
mtrai760's Avatar
BMWHIGH1 =
I don't want to reset the light the right way, I want to do it my way, GOSH!
Old Oct 2, 2007 | 03:50 PM
Stardust's Avatar
F---ing Kangaroos
- Vikas
I do the exact same thing
Old Oct 2, 2007 | 03:52 PM
Stardust's Avatar
F---ing Kangaroos
BMWHIGH1 =
I just watched Napoleon Dynamite about an hour ago
Old Oct 2, 2007 | 03:54 PM
BMWHIGH1's Avatar
BMWHIGH1 =
why dont you go and give the noobies help, and stop commenting on something i didnt ask you to.
By the way thats a nice picture of yourself, Loved you in Blades of Glory
Old Oct 2, 2007 | 04:03 PM
Stardust's Avatar
F---ing Kangaroos
Real good idea to yell at a moderator
Old Oct 2, 2007 | 04:13 PM
BMWHIGH1's Avatar
I'm not yelling it seems as though i come up with an idea, and your getting on me because there are other ways to clear the light and codes. I thought the purpose of the org was to come up with idea that everyone could share. If a newb asked a question everyone makes them search, but i'm simply giving a way to do something different and everyone is throwing me answer and different solutions which i didnt ask for. So you tell me whats up with that? (no disrespect though)
Old Oct 2, 2007 | 04:18 PM
BMWHIGH1's Avatar
See I didnt ask for help yet everyone is telling me what to do and how to do it, but the newb is forced to search for info that you are giving me because i came up with an idea which I am already aware of other solutions, just look at this thread and see what this Moderator said (Newbs....READ THIS BEFORE YOUR FIRST POST!!!
PrinzII)
Old Oct 2, 2007 | 04:25 PM
mtrai760's Avatar
Your idea sucks, and carrys no mechanical merit, do things the right way or don't do them at all. At the very least, don't post about it. You registered in Dec 2006, you = newb.
