Will a 5th gen intake fit a 5.5 gen Maxima?
Old Oct 7, 2007 | 05:14 PM
Rich96's Avatar
I had a 2000 and am selling my intake off of it. I had somebody with a 2003 interested in buying it.....will it fit? Stillen's website lists a different part number so I was assuming it wouldn't work.
Old Oct 7, 2007 | 05:17 PM
irish44j's Avatar
retired moderator
yes and no. An '03 can use it, but they'll have to plug the two small vacuum hose pipes, since the 3.5 only has a single vac hose, not three like the 3.0.
Old Oct 7, 2007 | 05:20 PM
Rich96's Avatar
I don't recall doing anything with vacuum hose pipes on mine....it just bolted right up to the intake mainfold.
Old Oct 7, 2007 | 05:23 PM
SoonerFan's Avatar
Cletus
you bolted your intake to your intake manifold?
i swapped my berk from my 00 to my 02...had to plug the two side holes on the tube
Old Oct 7, 2007 | 05:26 PM
SoonerFan's Avatar
Cletus
see where that large hose connects to the tube?
see the black tape?
thats coverering the extra holes (i broke the nipples off)
Rich96's Avatar
My bad, not right to the manifold....to the MAF housing......the Stealin consists of nothing more than the filter and velocity stack.
Old Oct 7, 2007 | 05:28 PM
Rich96's Avatar
see the black tape?
Sorry, I'm stupid.
Which tube are you talking about? The MAF housing?
SoonerFan's Avatar
Cletus
the stillen one is garbage since it doesnt have the midpipe. it will work
Old Oct 7, 2007 | 05:29 PM
SoonerFan's Avatar
Cletus
Sorry, I'm stupid.
diregard...its different for the stillen.
i meant the midpipe between the MAF housing and throttle body
Old Oct 8, 2007 | 01:06 PM
'02_EMILBUS's Avatar
That mid-pipe isnt there on the Stillen. You sayin just get rid of the Stillen and buy what??
I'm in the same situation as RichardO here...
Old Oct 8, 2007 | 01:32 PM
NmexMAX's Avatar
dot dot dot ...
If we are talking about the Stillen intake, there is nothing different. Stillen doesn't offer a midpipe, and that is the only place where the intake (post TB) is different.
The most important thing in this situation is MAF bolt pattern, in which case it will match up (00-03).
Old Oct 8, 2007 | 01:55 PM
yes... everyone knows that the stillen offers no mid-pipe. Some didnt like it and i asked what brand they do like. Yes the bolt pattern is the same but the other mounting bracket does not line up.
Old Oct 8, 2007 | 02:07 PM
NmexMAX's Avatar
dot dot dot ...
My Stillen bracket looks just like sooner's berk does in post #5. Works just fine too.
Old Oct 8, 2007 | 04:02 PM
Your bracket looks the same b/c your intake is for a 5.5 gen, correcT? The question was a 5 gen. Stillen installed on a 5.5 gen. The 00-01 has a different bracket.
Old Oct 8, 2007 | 04:07 PM
SoonerFan's Avatar
Cletus
bracket is the same
Old Oct 8, 2007 | 04:13 PM
NmexMAX's Avatar
dot dot dot ...
I've used a 5th gen Stillen intake in my 5.5gen. I've used a 5th gen berk midpipe and bracket with a Stillen intake. I've used a 5th gen stock airbox (not midpipe) in my 5.5 gen.
Old Oct 8, 2007 | 04:30 PM
SoonerFan's Avatar
Cletus
ONLY difference is the vacuum hoses
Old Oct 8, 2007 | 04:33 PM
NmexMAX's Avatar
dot dot dot ...
So then this means that the Stillen is identical for both 5 and 5.5 gens? Wow, 200-2003 Maximas can use the same intake of it is a Stillen unit?
Old Oct 10, 2007 | 03:03 PM
whorufool's Avatar
great info...so which one is it
Old Oct 10, 2007 | 03:19 PM
SoonerFan's Avatar
Cletus
PWing to get to 15 posts = ban
Finkle
Sep 27, 2015 09:53 PM
tcb_02_max
Sep 23, 2015 06:18 AM
tcb_02_max
Sep 11, 2015 12:23 PM
wyobbagy
Aug 15, 2015 02:28 PM
MaxStock
Aug 12, 2015 08:33 AM
