car bucking?
After I took my throttle body apart for cleaning .... like an a-hole i took off the tps. I put it on and didn't think anything of it. My car kept bucking like crazy but only at certain rpms. I adjusted it and there has been no more bucking.
Ok.. So my cheap generic code reader wasnt pulling up the code but it is cylinder 5 misfire i havnt changed my plugs yet and my car is at 78000 miles so im going to try that first got the plugs just need time to install them.. and i will check my coils with on on multometer the second i get my hands on one thanks everyone for your help!!!
Pull the coil first, plug it back in and plug in a spare spark plug, hold it to the intake manifold while you or assistant starts car, the plug can cause misfire code as well.
have you changed you fuel filter? I had that same problem so I replaced mine and it helped a little but not all the way but I also have a bad O2 still gotta replace that. and if you do replace your filter I was told get a 300zx filter.
I would try the following ::: new plugs first - if that doesn't do it, then do the coil pack. If the new plug and / or coil pack doesn't do it, try replacing the fule filter.
At first ... I though, learn how to shift mate! but ... I agree if you're pulling codes, that must be the reason! lol G'luck, keep us posted please.
Cheers ~!~
Cheers ~!~
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
JMag90
Aug 25, 2015 09:17 AM
District
Aug 15, 2015 08:23 PM
