Road noise reduction - anyone done it?
Old Oct 22, 2001 | 02:58 PM
stretch's Avatar
I've decided I'd like to make my 2k SE a little quieter for that long drive to work and back.. I have found a couple of places that sell mastic at reasonable prices, but I'm not sure what areas will give the biggest benefit. My instinct says door panels, but other people seem to favor the trunk.
Was wondering if anyone else has had much experience trying this, and what results they had gotten.
Old Oct 24, 2001 | 06:04 PM
spaaz14's Avatar
Take the trunk carpeting out and along the rear fenders there is alot of area tha is uninsulated. The sound from the trunk travels readily through the rear dash, too. Personally I think the most benificial place to insulate would be the whole floor, though I haven't been able to get to that yet. Hesitant because getting the seats and lower moldings to fit with ease afterwards is gonna be a PIA. Good luck!
Old Oct 24, 2001 | 09:37 PM
radpp16's Avatar
Re: Road noise reduction - anyone done it?
You know what,, this is an interesting post.. I want my interior ride to be quiet stealth also...
what is MASTIC? where can i get it for cheap?
Roger
Old Oct 24, 2001 | 10:04 PM
Ludacris's Avatar
Yeah sounds cool, the car has too much road rumble...even our GLE.
Old Oct 25, 2001 | 03:33 AM
areX's Avatar
you can use the same asphalt roofing stuff from Home Depot. it's the same stuff as Dynamat and Mastic, so i've heard... they were talking about this in the GB forum.
Old Oct 25, 2001 | 05:32 AM
UMD_MaxSE's Avatar
Got Bent?
modded cars are supposed to be loud
Old Oct 25, 2001 | 05:43 AM
victor's Avatar
i've been reading a lot on the www.sounddomain.com forums, and they have said that "undercoating" is good, i guess it's like a rubber coating that you spray on. it comes in a can. if you need more info you can go search or let me know and i'll go.
Old Oct 25, 2001 | 07:13 AM
TimW's Avatar
The silent but deadly Moderator
oh man...
that would make the rattles LOUDER tho
Old Oct 25, 2001 | 07:31 AM
Blackgums100's Avatar
Not easy
Read somewhere were a guy used the matting on his max and stated it was really time consuming and tedecious, took like 8 hours.
Old Oct 25, 2001 | 03:21 PM
Kostya's Avatar
Road Noise
My 2KSE does not have Bose audio. I was surprized to discover they did not soundproof the subwoofer hole in rear deck. Covering that hole reduced the road noise a lot, especially in the rear seat area.
Lemme know if you want to see the pictures.
Old Oct 25, 2001 | 03:24 PM
nc00max
Re: Road Noise
If it's something simple, I wouldn't mind a little how-to advice...
Old Oct 25, 2001 | 07:23 PM
woosh's Avatar
Re: Road Noise
Yep, I wanna see pictures
Old Oct 26, 2001 | 02:54 PM
Kostya's Avatar
Re: Re: Road Noise
Here is the picture taken from the trunk. Subwoofer hole is covered with blue foam. Sorry, don't have "before" picture
Old Oct 26, 2001 | 03:03 PM
Kostya's Avatar
Re: Re: Road Noise
Another hole (don't know why it's there). I stuffed a lot of soft foam (white) in the space between rear dash and trunk "ceiling" and then used harder foam (blue) to keep it in place. Definitely quiter now.
I usually don't use rear seat in my car thou
Old Oct 26, 2001 | 05:32 PM
mingo's Avatar
go to the "audio and electronics" section of this forum, a few people there are very knowledgable about sound deadening.. sweetsound2001, whitemax, turdfurgeson to name a few. they've all recommended a brand called rammat to me, however i can't get a hold of the guy that sells the stuff.. also a product called brown bread was brought up a few times on a car audio forum i used to participate in.. then there's also lowe's peel and seel. it's basically roofing material.. another method of sound deadening is using (very carefully) expansion foam. inject it in the rocker panels and cavities where it would be difficult to apply the mastics on..
user 11122324
42
Jul 18, 2022 03:35 PM
D Mason
Jun 21, 2016 04:43 AM
doctorpullit
Dec 12, 2015 09:39 AM
uttadms31
Sep 30, 2015 05:24 AM
