Progress spring install?
Old Nov 8, 2007 | 07:29 PM
anthny2040's Avatar
Im thinking about buying some progress lowering springs, how hard are they to install and what all is involved. Pics would be great to.
Old Nov 9, 2007 | 05:51 AM
VigilanteMax's Avatar
Pretty straight forward. takes about 4-6 hours when changing out your struts, shocks and springs as I did, but well worth it. there are some DIY sites and getting the 17mm and 19mm bolts of including the endlink bolt is basically what it entails. Also, removing the strut bolts on top. Make sure you get a spring compressor. i would also add the FSTB from racingline if you are going through all the trouble.
Stock spring with Progress comparison:
Before drop:
strut assembly off:
KYB GR2 with Progress springs on:
After drop:
Old Nov 9, 2007 | 07:35 AM
Mack's Avatar
Great post coitaltie!! Please tell me your car wasn't actually SITTING on the front rotor?
Old Nov 9, 2007 | 07:44 AM
coolmax05's Avatar
LOL I'm sure it is a optical illusion Mack.
I agree with you. A very nice post indeed.
Old Nov 9, 2007 | 07:45 AM
Mack's Avatar
Let's hope so!
But yeah, great pics and info man, I love these kinda posts. (even though I'm sporting Eibachs)
Old Nov 9, 2007 | 07:48 AM
yep sitting right on the rotor.....damn of course not... sitting on stocks. i appreciate the concern though. notice the bumper in the air.
Old Nov 9, 2007 | 08:03 AM
Mack's Avatar
Hey bro, are those stock calipers painted red?
Old Nov 9, 2007 | 08:48 AM
yes siry bob.
Old Nov 9, 2007 | 10:12 AM
Mack's Avatar
Sexy
Old Nov 9, 2007 | 10:24 AM
King James's Avatar
That's a good look.
Old Nov 9, 2007 | 11:17 AM
Much appreciated guys
Old Nov 9, 2007 | 11:20 AM
BigPete's Avatar
Incognito
pure secks
Old Nov 9, 2007 | 01:09 PM
anthny2040's Avatar
Well i will be using my stock struts, the only part i am worried about is changing the springs out in the front.
Old Nov 9, 2007 | 01:23 PM
Mack's Avatar
Anthony, I did that for a bit and didn't have any problems with my Eibachs on stock struts. However I've heard about quite a few 6th geners who have their stock struts blown out awhile after installing lowering springs. Basically it makes it so all the cars weight then sits on the strut. I upgraded to the Koni adjustables and rides like a dream now, thanks to my personal "suspension guy" Coolmax.
Also, it's good that you have a smoke Maxima. Not may folks know this but the smoke models are a cut above the rest.
(p.s. oops, I guess that's Dan with the smoke max).
Old Nov 9, 2007 | 02:04 PM
I can not lie...what Mack says is true. The Smoke maxies have a special purdy chip implanted. I would recommend replacing the struts bc if they do blow, you will have to do the same thing again. I got my gr2s (2 struts and 2 shocks) for $192 shipped and thats the cheapest you will find anywhere.
Old Nov 9, 2007 | 03:19 PM
TheCure411's Avatar
For those who have used the springs, have you noticed any rubbing while having passengers or maybe even luggage in the car?
and....can we see more pics? thanks
Old Nov 9, 2007 | 03:40 PM
Fastmax05's Avatar
"Ok,Whats next?!?!"
I dont have those,, but from what i hear there is NO rubbing issues...
I have H&R' springs w/ gr2's paired w/ my 20's, NO problems ANYWHERE!!
I know that the eibachs are a bigger drop... but i have not seen ANY threads on rub problems...
Here is a good view of my setup/space
Old Nov 9, 2007 | 03:57 PM
SmokinMaxSE's Avatar
SmokinMaxSE
This is because Smoke hides the ugly parts......
J/K
Old Nov 9, 2007 | 04:00 PM
J/K
True dat
Old Nov 9, 2007 | 04:32 PM
anthny2040's Avatar
coitaltie, you mind if i asked what springs and where did you buy your stuff for that price?
Old Nov 10, 2007 | 05:06 AM
The springs I bought used and they are progress. The struts and shocks are new from www.apwonline.com. No one can match this price or at least I have not seen advertised.
Old Nov 12, 2007 | 09:04 PM
04MAX4ME's Avatar
I just installed my Progress Springs. When I went to remove the OEM rear springs, I saw that they had a hard rubber insert (can't remember the proper name) wedged in the coils. Should I place the inserts in my new springs? Does it matter?
Old Nov 13, 2007 | 05:24 AM
If they are not damaged, they are fine to use.
MaxLife17
Jun 27, 2019 01:37 PM
BkGreen97
Apr 2, 2016 05:47 AM
Hdnseek
Sep 9, 2015 05:55 AM
lowpost99
Sep 8, 2015 05:06 AM
Johnny9595
Sep 3, 2015 05:18 AM
