after market head unit, no sound!!
Old Nov 12, 2007 | 05:38 PM
6SPD02SE's Avatar
I tried to install my Kenwood head unit in my 02 Max with Bose. I got the Metra-7550 wiring harness. Everything plugged in perfectly. The head unit has power but has no sound. Is this the correct wiring harness for my car?
Old Nov 12, 2007 | 06:26 PM
Batxel's Avatar
blah
You have bose, I believe you need a converter as well. It should be in the stickies some where.
Old Nov 12, 2007 | 06:56 PM
nismos14's Avatar
§è~® f®ÈÄk
You need the 70-7551, and you need to be sure to connect the remote wire.
Old Nov 12, 2007 | 07:24 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Please remove the 7550 ASAP. Very good chance (if you havent already) that you will cause damage. Use the 7551 as posted above for Bose systems.
Old Nov 13, 2007 | 03:14 AM
6SPD02SE's Avatar
I took it out and put the stoch head unit back in. Is the 7551 from metra? Is that all i will need?
Old Nov 13, 2007 | 05:25 AM
nismos14's Avatar
§è~® f®ÈÄk
7551 and be SURE to connect the remote wire to the amp turn on wire.
Old Nov 13, 2007 | 02:56 PM
6SPD02SE's Avatar
Which one is the remote wire?
Old Nov 13, 2007 | 05:37 PM
Pearl96Max's Avatar
The one labeled amp turn on.
Old Nov 13, 2007 | 05:42 PM
6SPD02SE's Avatar
Im calling Metra tomarrow and ordering the harness.
Mar 12, 2020 12:06 AM
ivorton23
Sep 28, 2015 09:08 PM
RWCreative
Sep 21, 2015 11:01 AM
dvcamp
Sep 18, 2015 10:17 AM
Maxie40
Sep 14, 2015 11:28 AM
