Who is running a 245/45 tire in the rear?
Old Nov 26, 2007 | 08:09 PM
Peanuthead's Avatar
Are you noticing any rubbing or that it is very easy to scrape the outside edge of the tire on a hard bump? I know the rear struts need to be replaced but the clearance even as it sits seems to be only ~1 inch. Would replacing the rear struts make that much of a difference? Or is the tire just too big in sidewall height?
The tire is a 245/45R18 on 18" 350Z rims (I think 30mm offset in the rear) on a 2001 AE.
Old Nov 26, 2007 | 08:28 PM
SuperStasiu's Avatar
Ahh whats the rim size and offset thats all that depends. I run a 245/40/18 with i think 43 offset i'm lowered on just springs and i've had 5 people in the car and no rubbing. I know a buddy that has 265/40/18 in the rear on coilovers and no rubbing. So a little more info would help buddy
Old Nov 26, 2007 | 08:31 PM
SoonerFan's Avatar
Cletus
Dear Peanuthead,
Thank you for visiting Maxima.org! Your stay here will be longer, more productive and infinitely more enjoyable for all involved if you direct your questions to the appropriate part of The Org!
While your question is, indeed, vaguely related to 5th Gen Maximas, it more specifically relates to Wheels and Tires (see link below). You are likely to get better, more specific help there.
Search first, post second!
Thank you! Come again!
http://forums.maxima.org/forumdisplay.php?f=53
Old Nov 26, 2007 | 08:32 PM
Peanuthead's Avatar
Details are updated in the first post.
soonerfan, thank you for the recommendation. I believe that this has a lot to do with the suspension travel on a 5th Gen. Maxima and not the tire size or aspect ratio of the tire. I did do a brief search and while I found people running this tire size there was no one saying that they had a rubbing issue. Hence, why my question above is directed to the rubbing of the tire and not to whom is running that size tire.
Old Nov 26, 2007 | 08:41 PM
CoolMax's Avatar
is invisible
Originally Posted by The Law
What is the offset of the rims? I know that when I had 245/45/18 on my eibach drop with +33 offset, I'd rub only when going over dips.
Old Nov 26, 2007 | 08:47 PM
Peanuthead's Avatar
CoolMax, +30mm in the rear.
Old Nov 26, 2007 | 09:17 PM
FlipCpt45's Avatar
my rear tires rub when people are in the back, 235/45-18, on the KV5, aka MM Evo5 Replicas.. also on a 2k1 AE
Old Nov 26, 2007 | 10:10 PM
AlpineGt66's Avatar
only on hard bumps, i think it has something to do with re centering the rear beam.
Old Nov 27, 2007 | 04:46 PM
qnpark8282's Avatar
i run 245 45 18, only my right side rubbs . its not the 1/4 panel thats rubbing its the piece where the bumper and the 1/4 meets. Right at the edge.
Old Nov 27, 2007 | 06:02 PM
KabirUTA13's Avatar
IN IRAQ MAXIMA.ORG-ING :)
im running 245 45 18s on my rims... slight rubbing only on dips... my rims are 18x9.5 which are freaking wide... but the offset is 35 which really matters...
Old Nov 27, 2007 | 07:13 PM
maximumobsesion's Avatar
i got 245 45 18 on 07 max wheels 40 offset no rubbing lowerd about 1.5 inches
Old Nov 27, 2007 | 09:16 PM
Peanuthead's Avatar
Thanks all. At least I know now that it isn't ENTIRELY the rear struts being gone. Thanks.
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
twotonezed
Aug 16, 2015 11:41 AM
mls277
Aug 11, 2015 07:18 PM
