Max Autocross
Max Autocross
She did pretty well for being stock. I raced in STE due to the time preference. Most entrants have suspension upgrades so I only got 4th out of 6 cars. I had a blast and it was really sweet not having to change tires before and after like I do in the truck. I pumped the tires up to 45 and the scrubbing stayed on the tread nothing too bad on the edges. Thanks to whoever recommended that. I was driving it pretty hard and the brakes worked very well. I don't have ABS up front on the Dakota and with Viper brakes it locks them up too easily. I could smash them down before coming into a tight turn or slalom without worry in the Max. The body roll was quite noticeable so I am considering some sway bar upgrades and the strut tower brace for sure. I prefer not to race it since I don't want to damage anything but fun on the street will appreciate the mods. Does anyone know the proper class for a stock car? H Stock? There was a TSX in there. I believe I would have gotten 2nd place in that. Not too bad for my first attempt. If anything autocrossing will help me get to know my daily driver better.
PM me if you have questions on this matter or for my exciting in car and outside videos at a high speed autocross/time trial.
Oh I forgot, get the best brake pads you can get, maybe Hawk HP series pads, high temp fluid, and if the class allows it, stainless steel lines (which I doubt are allowed in stock, but they may be).
hey guys , i have a i30 and i was thinking of doing something like auto crossing but i cant find on how to enter to one of them. i googles auto crossing and some crap came up. i live in new york so if u guys know a web site or something i can go to get some info can you please tell me thanx.
Try www.scca.com
thanx for the link but, after some thaught i decided that an i30 is not the car for this or the time for me to do someething like this and since im 17 and the car is really not my mine i should just couple of more years and get a manual and do some like this but i heard there are these evnts in englishtown new jersey so ima go check them out and see. thanx for the help
Thanks Deus. I have a small bubble on the left rear sidewall of the cruddy stock RSA's so I didn't want to go higher than 45. I doubt I will do any mods that increase the ride harshness as its where I want it now. On the street with that much pressure it was rough over bumps. The truck is very stiff and that is my regular autox mule. Prefer to keep the daily driver comfortable. It was neat being able to run well in something that gets good mileage, looks great and is somewhat luxury. Most of the larger cars do tend to prefer the open track or wider turn setup courses. Its way different on the road course as far as vehicle setup and driving methods. I've done Road Atlanta and MSR Houston plus the Atlanta Motor Speedway oval and inner road course, all are a blast. Are the Racingline end links a noticeable upgrade or are they mainly for adjustability of an aftermarket suspension? Sounds like the strut brace does well on its own.
No brake fade, they worked really well. It was a tight course setup for Miatas so the brakes were hit hard but only for short periods of time. Not a lot of heat built up to induce fade. I have confidence in them for longer usage and love them for street needs. I'm used to having to upgrade from stock, these are good to go. Tranny seemed to produce quicker times in auto mode, and aside from some traction control gremlins it did ok. A manual is a must for autox, once I get my gears straightened out in the Dakota I can run most events without shifting from 2nd.
Easy killer, its the only tranny available etc. Does anyone know if there is a built in stability control system that operates even with the traction control off? The power seemed to be getting cut as the demand came on coming out of a turn. I was surprised how neutral the car was in a sweeper, the car rotates nicely and has an even blend of under/oversteer. Most fwd's understeer awfully in stock form. No diagnostic codes or any weird signs from the CVT, but obviously its not the best choice for autox.
If you have any bubble in the tires I would NOT autocross or do any high performance driving at all. In fact, I would advise replacing the tire immediately. For autocross, you really need performance oriented tires. If your budget allows, get a spare set of rims, light ones if you can, with tires on them for competition only. The endlinks can be used with stock suspension. Its a great way to dial out some understeer. If you replace the rear bar, you can even get oversteer which is pretty cool. The reason the car cuts power with traction control on is because the timing is being retarded to allow the tires to regain traction. I race with TC on even if it cuts back power in the turns some. In three years of high speed competitions with my Maxima, the car has NEVER spun out ever. If you think its because I don't push it to the limits, then watch my in-car video sometime.
Agreed. Replace that tire with the bubble immediately. I'd suggest doing a few more events before buying any mods or wheels/tires. Seat time will get you more comfortable finding the course and getting more aggresive out there w/o making the ride harsh. You'll probably knock down another 5-10 sec as you improve. No mod can help more than "tightening the nut behind the wheel".
The timing cuts back when the Traction Control is ON. Thats how the traction is controlled - the timing is retarded which cuts power. My source is Tadashi from Technosquare.
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
magiconthetire
Oct 26, 2015 09:03 PM
maxima297
Sep 30, 2015 03:32 PM
