Fanbelts... 04 Max
Old Dec 7, 2007 | 07:59 AM
Propa Teknique's Avatar
Fanbelts... 04 Max
I'm tryin to find two fanbelts: one for the A/C and one for the Power Steering. Mines have several cracks and the dealer said that they should be fixed as soon as possible. I would much rather buy them for a cheaper price somewhere than to go to the dealer and they charge me 187.00. Are these the two fanbelts that I will need?? I think both come in the same order... I just need to be SURE they fit the 04 Maxes....
http://cgi.ebay.com/ebaymotors/ws/eB...ayphotohosting
Old Dec 7, 2007 | 08:07 AM
chernmax's Avatar
Nations 1st 6th Gen Turbo
Asking the stealership for the part numbers of the belts should have been free!!!
Old Dec 7, 2007 | 08:26 AM
Lol I know.... but its STEALERship for God Sakes... lol so are the ones in that link the right ones? I had an invoice from Firestone for my tires and it said some recommended services to my car would be the fanbelts, and the part numbers matched except on the Power Steering Belt... a couple of letters were off... so can you help me?
Old Dec 7, 2007 | 08:31 AM
Hilbe's Avatar
Should get and underdrive pulley (www.cosmoracing.com) while you're at it.
Old Dec 7, 2007 | 10:28 AM
ramberg's Avatar
GrandPa
Go to PEP Boys or Autozone. Tell them the year and make of your car. They should have them in stock. Is that 187 dollars with install?
Old Dec 7, 2007 | 11:44 AM
brio_max's Avatar
Learning English...
The 5,5th gen Maxima 02-03' has different part numbers for belts than the 6th gen A34...
But maybe they would fit the A34, who knows
WTF $187 just for belts? This must be a mistake.
Old Dec 7, 2007 | 12:10 PM
Hilbe's Avatar
Belts should be $15 (PS) and $20 (Accessories). Installation is where they'll get you.
As mentioned before, you should consider getting a pulley installed. The pulley install requires the belts be changed anyway. I got mine installed when it was time to change my belts. I got the install for $100, plus $35 for the belts.
Old Dec 7, 2007 | 02:05 PM
Lovemycar's Avatar
what is the pully
Old Dec 7, 2007 | 02:14 PM
Fastmax05's Avatar
"Ok,Whats next?!?!"
187 good lord... LOL.. i just did mine and it was 33 dollar with tax from kragen LOL
Old Dec 7, 2007 | 03:12 PM
Hilbe's Avatar
Originally Posted by Lovemycar
what is the pully
http://www.cosmoracing.com/productin...d=199&pid=1324
It makes the car rev a lot quicker since its a lot lighter than stock. I really enjoy the mod, regardless if it only adds a few whp here and there.
Old Dec 7, 2007 | 05:38 PM
Yeah they said 187.00 to replace and install that junk.. I was heated.... so I take it that the link I provided is not the right one? On the invoice from Firestone though it showed the A/C belt was the same as the one on Ebay.... how much should all that cost including the pulley, to be installed?
Old Dec 7, 2007 | 05:43 PM
Hilbe's Avatar
$65 pulley (shipped)
$35 belts
$100 to $150 labor
$200 to $250 total
I was at $200 or so total. I feel better having new belts and the pulley installed.
Old Dec 7, 2007 | 06:24 PM
Longhorn101's Avatar
I got the outer belt at Advanced for like $13. Piece of cake to install if you have a ratchet with a couple of long extensions. I did not do the P/S belt because it looked good.
Have any other 2004 owners noticed that Autozone has the wrong part numbers on a bunch of parts for our vehicle. The part number for the belt is different at Autozone than at two other stores I checked and it seemed to match the 2003 part number. I think their part list is f.....d up for 2004.
Old Dec 8, 2007 | 10:28 AM
Well I wont go to Autozone.... I just really need to get that $h!t changed because its started to screech and its annoying! And I definitely will get the pulley too Hilbe
Old Dec 8, 2007 | 10:47 AM
Hilbe's Avatar
You will need a different Power Steering belt if you get the pulley. Its smaller. I have a thread on here somewhere for it, lists the belt required. It'll take the same size accessories belt though...
Old Dec 19, 2007 | 11:59 AM
ReficuLiu's Avatar
Hi,
I just got the warning from the Stealership as well regarding my cracking drive belts. I just spoke with my friend and he said it might be hard to change.
Longhorn101, is it really easy to install? i really don't want to be fishing out $1-200 on labor but likewise dont want to F up my car badly. . Does anyone have the instructions to the replacement? i'm pretty ignorant when it comes to DIY maintenance. Any help with How To or required tools? Thanks!
Old Dec 19, 2007 | 12:02 PM
cefiro80's Avatar
Should be a lot cheaper then quoted price.
Old Dec 19, 2007 | 12:04 PM
Hilbe's Avatar
Originally Posted by ReficuLiu
Hi,
Pay someone. Its the only mod I paid to have done. (Mentioned earlier) I had them put on a underdrive crank pulley, since you change the belts to do that as well. Out the door for me was $200 including new pulley, belts, and labor.
Old Dec 19, 2007 | 06:35 PM
Hi,
I only did the outer belt (wider one) and yes it was easy. I'm not sure about the inner belt because I don't know where the tension adjustment is for that inner belt which i think is only the power steering belt. The generic instructions are to jack up and support, remove passenger tire and the splash shield covering oil filter and belts. Loosen the tension adjustment from above in the engine bay which I think required some long socket extentions. Remove old belt, install new belt and re-tighten to correct tension.
Old Dec 20, 2007 | 09:28 AM
ReficuLiu's Avatar
Hmmm sounds pretty straight forward. I think i could probably get that done, but im lacking the equipment .. . i only have the regular jack, and a set of ramps. I guess ill try it if it really starts to bother me. Somehow though, i highly doubt i need to be changing my belts at 38K miles. But yah its probably a good idea to still try to check up on it. Thanks for all the help though!
Old Dec 20, 2007 | 09:39 AM
BigPete's Avatar
Incognito
I just had mine changed. 37k miles on my car. Stealership charged me $175.00 for both belts and labor. Its a good 1-2 hours of labor which doesnt come cheap at the stealership.
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
magiconthetire
Oct 26, 2015 09:03 PM
maxima297
Sep 30, 2015 03:32 PM
