Garage and Workshop This forum is for discussions of what goes on in the garage - "the tools, the techniques, the tricks" ...or something like that. DO NOT POST QUESTIONS ABOUT YOUR CAR HERE.
Garage Storage Ideas - Overhead Storage
Old Dec 11, 2007 | 07:42 AM
Puppetmaster's Avatar
I have pretty high ceilings in my garage and was thinking about how to make use of the space (other than putting in a lift, which will not happen any time soon).
Anyone has these Onrax things or something similar in terms of overhead storage? Thoughts and comments?
http://www.onrax.com/
I'm probably going to put some shelving along the rear wall and maybe a work bench plus pegboard along one of the side walls.
Old Dec 11, 2007 | 08:09 AM
phenryiv1's Avatar
Mod her. Ate her.
Build a rack like Josh and I did:
Old Dec 11, 2007 | 08:34 AM
Cutler's Avatar
Joel you know you like the idea , I personally like the first one. It looks just like your garage.
Old Dec 11, 2007 | 09:24 AM
IMG]http://i90.photobucket.com/albums/k271/phenryiv1/House/Garage001.jpg[/IMG]
Yeah, I plan on doing that for the back wall, and maybe even one of the side walls. I just want to make some good use of all the air space I have above the garage door. I'll try to post a picture later.
Old Dec 11, 2007 | 09:25 AM
I do like it. Just wondering if anyone else had any input or better ideas.
Old Dec 11, 2007 | 09:41 AM
I've got something I think you guys will like. Pics to follow.
Old Dec 12, 2007 | 06:34 AM
phenryiv1's Avatar
Mod her. Ate her.
You can replicate what they have built with some steel from HD or Lowes and a sheet of plywood. I never looked closely at the pics that you posted until now, but it basically mounts like a garage door opener.
Butt-simple to do.
Old Dec 26, 2007 | 10:06 PM
D-Bo's Avatar
Droppin logs
I had my last garage setup exactly like this, great use of wasted space and I found the racks on sale at Target. Mine held up fine for ~2 years before I moved.
Old Dec 26, 2007 | 10:13 PM
A33 VQ30DEK's Avatar
some dude built a big rack in my garage on the ceiling! I put all my car parts there!
Old Dec 27, 2007 | 07:37 PM
irish44j's Avatar
retired moderator
Joel.....
big basket or custom-built shelf
pulley system attached to ceiling
overhead storage that you can raise/lower to load it up without a ladder.
If my garage overhead was higher than 9' or so I would...
Old Dec 28, 2007 | 05:43 AM
phenryiv1's Avatar
Mod her. Ate her.
Originally Posted by irish44j
Joel.....
Joel and I are so short, we should just leave the baskets on the floor.
Old Jan 3, 2008 | 06:11 AM
For now, I'm going to do the custom racks on the side/rear wall like you guys, then see if I really need the extra storage up top. That can always wait until later. I also still have a basement storage room and closets.
Old Jan 3, 2008 | 06:13 AM
I always thought 5'9" - 5'10" was average....
Then again, it is relative...
Old Jan 10, 2008 | 02:24 PM
petersenj20's Avatar
I would only install these in a truss roof. That may not be a problem, but it is something to think about. A lot of carpenters and weldors do this same thing for storing lumber and steel.(Respectively)
Old Jan 31, 2008 | 05:31 PM
D-Bo's Avatar
Droppin logs
Not quite sure where you're going with this but yes you wouldn't want to anchor something like this in the drywall. That's why they include gigantor lagbolts for installation.
Old Feb 4, 2008 | 05:38 PM
irish44j's Avatar
retired moderator
I would run an auxiliary beam with posts at each side of the garage. Let them support the weight rather than the floor of your bedroom/kitchen/whatever.
+1 on the truss ceiling. I wouldn't hang much weight from a standard 4x6 joist....
Old Mar 15, 2008 | 07:08 PM
croser2's Avatar
I built an overhead one out of wood. Made it 4x8 so one big piece of plywood wood fit nicely. I put it in a corner, so I used lag bolts to but a 2x4 on one wall and used the existing header on the other. I then attached 2x4's with lag bolts to every joist on the roof (Slanted, unfinished ceiling). These held another 2x4 parallel with the one on the wall, and then I put some across like slats.
Took an afternoon, cost under 50 bucks, and I only needed a hand from my dad on putting up the 4x8' plywood.
Then I moved.... :/
Old Sep 24, 2012 | 01:52 AM
kylaarmstrong's Avatar
I installed an overhead storage organizer like yours, but the height could be adjusted based on my needs. I think, you should have bought such a system and best utilize the space.
Old Oct 4, 2012 | 06:30 PM
Requin6's Avatar
Joel, you probably already have it figured out since this thread is over 4 years old. I was about to buy some Onrax or something similar but just couldn't justify spending over $300 for one shelf.
Fabbed up something similar out of wood and 90 degree metal. Did 2 shelves like this (put up another one on the opposing side) for about $100. Painted it to match the cabinets in the garage. Turned out pretty nice.
Old Nov 18, 2012 | 10:34 PM
priscillaG31's Avatar
Nice idea. I will try to apply that to my garage to keep my things and foe clean look.
Old Nov 30, 2012 | 01:26 AM
candacelentz31's Avatar
Garage storage is often intended to make efficient use of space.
It may also hard to access when needed because of its height. But it well help to keep our things arrange and spacious area.
user 11122324
42
Jul 18, 2022 03:35 PM
tarun900
19
Dec 20, 2021 06:57 PM
Justin Kroll
Oct 1, 2015 07:03 PM
maxima297
Sep 30, 2015 03:32 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
