window switch LED issue, no window is on the fritz ....
Old Dec 14, 2007 | 09:10 PM
big_dawg's Avatar
A couple years ago I bought a set of blue LED modded window switches. When I put the driver's side switches in I forgot to drill the hole out a bit for the larger LED, so I think I messed up the door lock/unlock and window lock/unlock lights a bit. After years of use I finally felt like trying to fix them, so I took everything out and tightened up the soldering. Now the lights don't work and the driver's side window will only roll down then up once before it locks up. What can I do? Now I can't go through drive-thru's for dinner anymore! Anyone in So Cal area that can help out?
Any help is greatly appreciated!!!
Old Dec 14, 2007 | 09:24 PM
MOHFpro90's Avatar
Did you use 5mm LEDs?
Old Dec 15, 2007 | 11:25 PM
vilmaxima's Avatar
maybe by accident u got some soldering run-off, and its f***ing things up(going onto more than one connection)
Old Dec 16, 2007 | 01:11 PM
JtzMax's Avatar
Whatchyou say?
have you taken the switch apart ... to see if it is possible that solder did just as mentioned above? if not ... start there. it could also be that you have just woren out the switch it's self. (doubt it ... but it could happen)
The Frye
Feb 3, 2019 08:34 AM
ef9
Sep 5, 2015 11:18 PM
maximusrising
Sep 4, 2015 06:31 PM
dcardello
Sep 3, 2015 11:44 PM
