Front/ Rear endlinks
Old Dec 16, 2007 | 08:17 PM
MiamiBlackMax's Avatar
I will be doing the the front and rear endlinks this coming weekend but wanted to get any heads up from the ppl who already have done them? any advise? anything to watch out for? a guide to installing them? Thanks ahead of time
Old Dec 18, 2007 | 11:08 AM
QwikKota's Avatar
Bump.
Pre-Load tips anyone?
Old Dec 18, 2007 | 11:16 AM
Hilbe's Avatar
Make sure to put both sides of the car on jack stands. Jacking one wheel up at a time puts tension on them and makes them a bit more difficult to get on/off. I jack one wheel at a time and put a second floor jack under the wheel hub though
Also get some bolt buster and have a breaker bar handy. I can't seem to bust the bolts on my fronts, otherwise those would be on by now. I just ordered an air ratchet I'm going to try...
Worst case the dremel comes out and I cut those bolts off...
Old Dec 18, 2007 | 11:33 AM
QwikKota's Avatar
Careful with that air ratchet. They don't have an internal clutch like an impact and can smash your hand into the frame or something solid if the bolt doesn't let go. PB Blaster is my favorite, but Liquid Wrench is cheaper and easier to find. Does anyone make a front sway bar upgrade? I believe I read the Altima SE-R's fits? Probably hard to find used.
Old Dec 18, 2007 | 11:50 AM
Hilbe's Avatar
Once you get the wheel off, its just 2 bolts on each endlink. Simple.
I'm concerned about the smashing of fingers. We'll see.
Old Dec 18, 2007 | 12:41 PM
Mack's Avatar
http://forums.maxima.org/showthread.php?t=543640
Old Dec 18, 2007 | 01:14 PM
DeusExMaxima's Avatar
The SE-R bar does fit. Part number ends in ZB900 I believe.
Old Dec 18, 2007 | 01:21 PM
QwikKota's Avatar
Originally Posted by DeusExMaxima
he Se_R bar does fit. Part number ends in ZB900 I believe.
Cool, is it stiffer than the Max's? I bet they are expensive new from the stealership. Thx
Old Dec 18, 2007 | 01:41 PM
The bar, bushings and brackets are about $100 from stealership, quite a bargain and its 2 mm thicker than the Maximas. Search on here for threads on this good topic.
Old Dec 18, 2007 | 02:03 PM
!PrjctMax!'s Avatar
$92.44 shipped with brackets, bushings and bar from....a site that is not book-marked on this computer! I'll get back to you on the site
Old Dec 18, 2007 | 05:57 PM
QwikKota's Avatar
Thanks a bunch to you and Deus. I def want to get that and that is a really good deal. Is the SE-R rear bar worth upgrading to? I am trying to snag that Progress bar so I will prob go with that anyway. If you could get that URL that would rock.
Old Dec 18, 2007 | 06:15 PM
thanks for all the help...this weekend im going to do the most of the suspension (front & rear endlinks, struts/shocks, swar bar,FTB,springs) so ill post up pics soon
Old Dec 19, 2007 | 12:46 AM
Cant go wrong for $90 for front. Sway bars make a significant difference in handling.
Old Dec 19, 2007 | 03:55 AM
Hilbe's Avatar
Can't this Altima Nismo bars also be used. I read those are the thickest. You get both front and rear together for $350 I believe....
Old Dec 19, 2007 | 05:22 AM
QwikKota's Avatar
I had done a full susp. swap on one of my first vehicles and it was too harsh of a ride so I put the factory suspension back on with good shocks and the aftermarket sways. It had a great mix of ride and performance. Not near as good of handling but body roll is really annoying to me so minimizing that is my goal. I am not sure if the front end links will reduce it or are more for fine tuning you turn in and pre-loading the bar, etc. If they help I will eventually get them.
Old Dec 19, 2007 | 09:05 AM
Endlinks reduce roll because there is less play. They are MUCH stouter than the spindly factory units and they look pretty damn cool too.
Old Dec 19, 2007 | 10:40 AM
QwikKota's Avatar
Cool. Now to find the seller of the SE-R bar. Was it from a dealership giving discounts? Thx
Old Dec 19, 2007 | 11:07 AM
!PrjctMax!'s Avatar
Sorry for the website delay, but here it is.
www.1stAAANissanParts.com
You can find the part #'s in the stickies, or just give them a call
Good luck,
Dan
Old Dec 19, 2007 | 11:12 AM
!PrjctMax!'s Avatar
I know that the front NISMO is a little thicker than the SE-R bar, but the rear NISMO is just as thick as the Cattman, or visa versa...either way $115 (around there) for the Cattman + $92.44 (unless prices have changed) for the SE-R bar =$207.44 SHIPPED compared to NISMO's $350 + shipping probably
Cattman/SE-R > NISMO on pricing
NISMO > Cattman/SE-R "NISMO" and slightly thicker bar
Old Dec 19, 2007 | 11:27 AM
QwikKota's Avatar
Good luck,
Dan
Awesome, thanks Dan. I see that the 2006 SE-R bar is only $75 shipped, that's great. I take it I also need to buy the bushings as well? Do the factory brackets/clamps for the main bushings work? I'd prefer polyurethane, Energy Suspension probably has something but they are only $6 from that site. I appreciate, bookmark added.
Old Dec 19, 2007 | 11:32 AM
!PrjctMax!'s Avatar
!DO NOT, DO NOT, DO NOT, DO NOT! Get Energy suspension bushings for the FRONTS...you can get them for the rears, but NOT for the fronts! I said NOT, right?
When I did the SE-R bar mod, I ordered to sets of proper sized bushings from ES and the rears will work, but the fronts have a retarded bracket that will not accommodate the ES bushings, nor will the brackets that ES provides fit because of the design Nissan has.
Old Dec 19, 2007 | 11:40 AM
QwikKota's Avatar
Ah, that sux. So just use the traditional rubber bushings. What about our factory brackets? I didn't really see a place to buy the Altima brackets and there is no specific bushing for SE-R's. Just 04-06 etc. Lol, I finally figured out what the oldthread vs showthread address did. Sway Bar upgrade link
CRAP! I forgot how much of a pain it was to get the steering rack out/in on my 96 and how the sway bar was in the way. Doh! I will contemplate this mod but that is a major amount of work for a simple sway bar. Dangit...
Old Dec 19, 2007 | 11:42 AM
!PrjctMax!'s Avatar
Ya, you have to use the bushings/brackets that come with the SE-R bar.
When my tech did this, all that he did was drop the subframe and there was no problem with the steering column like Deus had
Old Dec 19, 2007 | 11:52 AM
QwikKota's Avatar
I could get the bar out of my 96 without dropping the subframe but I do believe the rear motor mount had to come down and the front to rear crossmember thing. That sucked and I bought this car not to have to work on it, lol. Rear bar, intake etc is cake. I do all my own work so my free time is directly related to mod wrenching time. Def don't want to mess up the alignment, hard to get the steering wheel recentered without an alignment.
Old Dec 19, 2007 | 12:10 PM
cefiro80's Avatar
That is the technique I used but make sure you have hte breaker bar handy and some pb blaster helps as well.
matts95max
Apr 23, 2025 10:44 AM
GregL65
Jan 17, 2020 08:01 PM
Y2kMaxima
Wheels/Tires
Sep 14, 2015 10:56 PM
bbsitum
Sep 11, 2015 04:55 PM
