Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
rear wheel offset and handling effects
Old Dec 21, 2007 | 04:12 PM
rxm6's Avatar
Max's and I30's came from the factory with a 20mm offset on the rear wheels vs. the front wheels. Was there an engineering reason for this or just cost effective? Will pushing the rear wheels out with spacers offer any greater handling characteristics or is this solely for aesthetic reasons?
Old Dec 21, 2007 | 07:08 PM
MorpheusZero's Avatar
It's better described as a front vs. rear track difference... I think it partly involves the lateral movement of the beam with rear suspension travel, and I think it's common practice on most cars with a solid axle. This is just speculation though, so don't quote me on that; I just seem to remember Mustangs etc have the same property.
Old Dec 21, 2007 | 07:34 PM
irish44j's Avatar
retired moderator
typically the rear wheels are in further to clear the wheel wells on stock springs when you have your three buddies in the back seat who are offensive linemen and a trunk full of beer cases.
basically, it's to allow clearance for the rear to sag excessively with a heavy load (or trailer) without rubbing the fenders.
Even my Cherokee has a narrower track in the rear than in the front....
Old Dec 22, 2007 | 08:14 AM
SNOMAX's Avatar
PM me for LCA's!
A wider front track also helps counteract understeer. If you are lowered or running more negative camber, increasing the rear track width would bring you a little closer to the factory handling balance.
Old Dec 22, 2007 | 12:40 PM
...Solid axle...
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
stromm
Aug 27, 2015 04:13 PM
twotonezed
Aug 16, 2015 11:41 AM
