Power steering problems.. (4th gen)
EDIT:
My power steering reservoir is going down kind of fast. I am wondering if changing the hoses (specifically which one) would be an easy job or if there is something else I should check.
Would it be worth looking into and doing on my own?
I've always had PS problems with most vehicles. It seems after a certain mileage it gets leaky and the PS reservoir drinks.
I have googled and searched here on forums max but didn't get much results. I dunno if this is a BIG BIG job worth doing or if I should just constantly top off w/ fluid.
Will air getting into the system hurt it? (i read this before somewhere).
Can I replace some hoses before extreme changes?
Thanks.
Thanks.
Anyway, if what is a big job? You didn't list a specific task.
Replace the PS pump? Not all too difficult, but by far not the easiest.
Hoses? Simple.
Reservoir? Simple.
Rack? Have fun...
Air won't 'hurt it', per se. It's supposed to be a self-bleeding system, by design.
If you're looking for just 4th gen responses: http://forums.maxima.org/forumdisplay.php?f=6
Hoses? Simple.
Reservoir? Simple.
Rack? Have fun...
Hoses? Simple.
Reservoir? Simple.
Rack? Have fun...
I have searched on the 4th gen for some writeups but didn't find much specifically on the job.
Thanks.
merry christmas
I still don't understand what's leaking or troubling your power steering system.
Your post makes no sense.
Santa was very good to me this year.
The only trouble are the leakages that concerns me. I never had to top off until recently through inspection, I noticed the level have dropped kinda low and kinda too fast. I am wondering if this is linked to my rack/pinion and whatever sounds/suspension/steering noises I might be experiencing (posted in 4th gen).
In terms of problems and other leaks, this has affect my older accords. The leakage in the hoses, lines dripped onto other things. Well as you know, it leads to belts snapping. Clearly something is wrong if the fluid is draining that fast.
I am not too familiar with power steering system and what not. If air getting into the system isn't a problem. I thinK i can probably just drain it and change the hoses and bleed it with ease. With other makes and model, I was told, never to let air get in.
vingodine
45
May 21, 2016 12:46 PM
Mrbizness1
Aug 18, 2015 08:43 PM
