Nismo key in a 99 w/immobilizer?
Can the 'all metal' Nismo key be used in my 99 SE-L with the immobilizer if I were to take the chip out of the OEM key and plant it somehow within the steering column close-by to the ignition cylinder so that the signal is still picked up? Has anybody done this before? I have searched but without luck.
Rather than just take the chip out, why dont you just keep the original key taped under the dash or within range from the immobilizer. Then you can use any key (whether it is a $2.00 hardware store special, or the NISMO key that you are talking about). What's wrong with the original key?
The only issue with the original key is that the corner where the chip is positioned has a small crack in it. I don't want to get moisture in there or anything as the gap is big enough for water to seep in. Taping the entire key under the dash may be too far away from the ignition, no? Plus, leaving a functional key in the car makes me feel a touch unsafe.
05RLS2
Apr 14, 2016 11:49 AM
ToTheMax305
Sep 23, 2015 09:11 PM
