OEM GXE Fog Light Wiring (who the heck has 56K these days?)
Old Jan 10, 2008 | 08:00 AM
maxitech's Avatar
So I'm going to be wiring in an OEM GXE fog light kit here as soon as I figure a few things out. And I have already verified that no pre-wiring for the lights exist. The following pics will help illustrate my questions:
Here's the lamp (obviously there's 2 of them):
The lamps plug into these (2) connectors on the wiring harness:
Now here's pics of the rest of the wiring harness:
There's a fuse / ground:
Old Jan 10, 2008 | 08:02 AM
maxitech's Avatar
Then there's this plug and this relay that plugs into it:
Then we've got this connector which must be to attach this purple wire to something, but what?
Old Jan 10, 2008 | 08:05 AM
maxitech's Avatar
Then there's these 3 wires with connectors on the end:
Which (possibly?) should be connected to the back of the dash switch:
Old Jan 10, 2008 | 08:07 AM
maxitech's Avatar
Then there's a blue relay I'm missing from the fuse box in the engine bay:
So I guess there's 2 relays involved in this setup (both pictured)...BTW, if you have an extra blue relay, I need it!
Old Jan 10, 2008 | 08:10 AM
maxitech's Avatar
Oh, and there's also this, which I'm assuming gets connected to the positive battery terminal for power:
So if you can tell me where to connect those wires to or have any other knowledge or insight, let's here it!
To recap, my guess is to tap the purple one into the wiring harness and to connect the 3 with connectors to the dash switch, even though the dash switch has 6 prongs.
And I'm not 100% sure if I need the blue relay since the kit comes with a black one...
Old Jan 10, 2008 | 09:42 AM
gapboi210's Avatar
Odd, my current Max isn't prewired either and it doesnt have a spot for a relay in the box.
Old Jan 10, 2008 | 12:22 PM
BenStoked's Avatar
Jesus was a Zombie.
okay, you say the car has no wiring for it. did the fog switch come off your car, or did you get it seperate?.
second, the fuse with the "ground," usually, (from what ive seen) the positive is fused, but could be wrong.
is this supposed to be half Q and A, half write up?
edit: can you post a picture of the wiring from the relay? or at least colors for the terminals?
Old Jan 10, 2008 | 01:03 PM
BenStoked's Avatar
Jesus was a Zombie.
can somebody post a pin out of the fog switch?
edit: never mind, its in the fsm
Old Jan 10, 2008 | 01:27 PM
maxitech's Avatar
fog switch is from a parts car, as stated...
And yes, I supposed this is part Q & A and part write-up...good call on the fuse, too.
Old Jan 10, 2008 | 01:30 PM
internetautomar's Avatar
mod or sell?
if I had it all in my hands, I'd be able to figure it out in a couple of minutes, but I'm lousy at wiring over teh intarweb
Old Jan 10, 2008 | 01:49 PM
BenStoked's Avatar
Jesus was a Zombie.
id still like to see the relay wiring, accompanied by the relay as it would be installed.
then i think i can write it out.
my concern is the green wire going to the switch. if i can figger it out, i think i got it.
edit:also the color of the terminal in the last picture.
Old Jan 11, 2008 | 02:18 PM
maxitech's Avatar
Pics of harness:
And the terminal pictured in the previous post has 2 green wires goin into it.
Old Jan 11, 2008 | 05:04 PM
BenStoked's Avatar
Jesus was a Zombie.
based on what i can tell, the green to the switch doesn't do anything, as shown:/. it could be used to light the switch, but i dont know...
im gonna throw this on here, see if its right.
as a suggestion, "wire" it up using a good battery first to check my connections.
1.) run wiring to appropriate locations, with
. a.) the switch wiring to the switch location,
. b.) the light wiring to the appropriate lamp locations,
. c.) the battery terminal to the battery (do not connect, yet),
. d.) the ground terminal to an appropriate grounding location.
2.) install the fog switch into dash. the stock location on my '91 se is the spot closest to the door.
3.) connect the switch with the following wires.(ignore colors from pic...)
. a.) green to 6
. b.) yellow to pin 2
. c.) purple to pin 1
4.) install the relay into the harness and secure into a suitable location.
5.) connect the single purple to a location such as the main radio power for power when on (acc) or (run), or to the running lamp wiring, so the lights come on with the running lights.
6.) install lamps into proper locations, and connect them.
7.) connect the battery cable and test.
please post results.
Old Jan 12, 2008 | 08:38 AM
maxitech's Avatar
I'm thinking the black relay on the wiring harness takes the place of the blue one in the fuse box...What do you think?
Old Jan 12, 2008 | 12:59 PM
BenStoked's Avatar
Jesus was a Zombie.
yeah...
btw, the reason i asked if the switch came with your car, is because i was wondering if there was a spot for it
I just realized that my step 2 is incorrect. the switch goes on the left side of the steering column, closest to the column.
when i wrote that, i called from memory, and later realized my mistake and meant to fix it, but forgot...
Old Jan 12, 2008 | 03:30 PM
maxitech's Avatar
Originally Posted by benstoked
yeah...
Yep, the switch goes in that spot, which currently has a dummy switch (or whatever you call it) in it.
Old Jan 13, 2008 | 06:13 PM
mrkanda's Avatar
Taking my Maxima to the Max!
Somewhat related question: Where did you get this GXE fog light setup?
The reason I ask is because I also have a GXE w/o fogs and have been looking to install some. Unfortunately the only ones I have found were on eBay and when the guy sent them to me they were all bent and rusted out. Do the ones you have come with the mounting brackets for the lights also? I'm not sure if I have the wiring harness in my car or not. I will check.
Keep us updated. Thanks.
-Mrkanda
Old Jan 13, 2008 | 07:24 PM
BenStoked's Avatar
Jesus was a Zombie.
sorry about your purchase. are the lights salvageable, by sanding and repainting?
one option is to buy the components separately.
split loom wire holder(?), 16g wire(alot, with different colors), automotive relay with socket, oem fog switch, terminals/connectors, and shrink tubing. prolly about $50...
Old Jan 13, 2008 | 08:12 PM
maxitech's Avatar
The lights were a rare dealer-installed option manufactured by Nissan. I hadn't ever come across a set until I bought them from another member who had had them sitting around still in the box for several years. I'll post the part # if you'd like.
Old Jan 13, 2008 | 09:39 PM
gapboi210's Avatar
WHy do u have a spot to plug in a relay but ur not prewired? Mine isnt prewired and there is just a blank open spot in the relay box.
Old Jan 14, 2008 | 06:00 AM
mod or sell?
economy of scales.
Old Jan 14, 2008 | 04:50 PM
GRNMAXDMON's Avatar
my GXE came pre-wired for the fogs so all i had to buy was just the fogs, the switch, and the relay. can anyone give me the dimesions of our fogs?
Old Jan 14, 2008 | 07:14 PM
maxitech's Avatar
Which ones? SE's or GXE's...
Old Jan 15, 2008 | 12:04 AM
mrkanda's Avatar
And the brackets, right? If not, where did you get your brackets?
Old Jan 15, 2008 | 11:46 AM
GRNMAXDMON's Avatar
for both.
Old Jan 15, 2008 | 11:47 AM
GRNMAXDMON's Avatar
i have aftermarket fogs from eurolite so yeah, the brackets came included with the eurolite fogs. i will change them since the glass lens broke so i will be going back to the stock fogs.
Old Jan 22, 2008 | 07:27 PM
BenStoked's Avatar
Jesus was a Zombie.
have you installed this yet?
just asking for an update...:\
Old Jan 22, 2008 | 08:28 PM
maxitech's Avatar
Not yet, the car is currently sitting on jackstands while I rebuild (and clean and paint) the brake calipers. Next up is the wiring, then the transmission. I will let you know as soon as I try it out, but it may happen next week, it may happen next month.
The two main contributing factors to my procrastination are that I need to have a resume, etc. ready to give to several companies in about 2 weeks (haven't started yet) and that it's below zero with the wind chill outside and my garage heater is much more effective when it's a bit warmer. No worries tho...it will get done soon!
Old Jan 23, 2008 | 04:52 AM
Obsession_92-94's Avatar
I had a 92 Maxima SE back when I was in highschool and the foglights would not work. I tried replacing the bulbs and the relay and still nothing. Any ideas to what might have been the problem?
Old Jan 23, 2008 | 05:58 AM
gapboi210's Avatar
are u asking for help on a car that you used to own but no longer have?
Old Jan 23, 2008 | 11:35 AM
Yeah, sort of. I just never found out the problem and it has sort of bothered me for a while now. I am looking to get another one though, but they seem to be very hard to come by in Columbus...
Old Jan 23, 2008 | 11:42 AM
BenStoked's Avatar
Jesus was a Zombie.
may have been the switch, or terminals to the lamps. i understand the question, and why, but its in the past, and you do not have to worry about it unless you get another one that has the same problem.
hope you find one soon. gl with the hunt
Old Jan 23, 2008 | 04:51 PM
I was thinking that it could have been the switch, but I was a naive lad then and did not want to upset the dashboard panel getting to it. I gave up on the matter when it was sold by my dad against my will.
Thanks for the support! I was close and then found that he sold it already...just a matter of time.
Old Feb 18, 2008 | 10:11 AM
maxitech's Avatar
Even though this discussion has given me a reasonably good idea of how to install these things, I still want a copy of the official install instructions...I KNOW they're out there! I can't for the life of me find them tho...
Ricky- You work at a Nissan dealer, correct? If so, any chance you could check into this?
My other idea is someone else could order a set and post up the instructions. They really are nice lights and are totally worth buying. Heck, I'm almost to the point of ordering a set from the dealer just for the instructions and then reselling them. Here's the part #'s if anyone is interested:
Fog light kit: 999F1-A000
Installation kit (brackets): 999F1-J9000
I'd be willing to bet the quality of these things is better than any of the aftermarket lights people have used in the past...
Old Mar 4, 2013 | 07:36 AM
nismax1994's Avatar
For the record, the GXE fog lights seem to be a common part. Here are some more numbers. I see them on amazon, ebay etc.
OEM # : 999F1-AA002
PartsLink # : NI2592113
note: this is just the light itself, you will need to have the oem mounts already on your GXE
Old Mar 4, 2013 | 08:04 AM
DMad8724's Avatar
the GXE fogs are also used on 00-01 Nissan Xterras, same light just different brackets between the 2 cars.. Also the OP refers them as being made by Nissan, However the GXE fogs say "BOSCH" across the front of the glass.
Old Mar 4, 2013 | 08:31 AM
CapedCadaver's Avatar
Call me Wookiee Goldberg
I doubt how much stuff is truly "made by nissan" other than major engine/frame parts. A lot of the sensors are hitachi and whatnot, injectors are bosch, etc etc.
Old Mar 4, 2013 | 09:04 AM
nismax1994's Avatar
Some of the reproductions may be plastic, which is probably not so bad. As I remember the OEM (bosch) glass I had were cracked in less than a year. If you do want glass order from courtesy with the OEM part number. I hope this helps anyone who is searching for GXE fogs and not finding anything.
Old Mar 4, 2013 | 01:54 PM
DMad8724's Avatar
is the GXE assembly comparable to the SE? ie does ordering the glass get you the glass + reflector. unbolt from the housing the same?
Old Mar 4, 2013 | 03:36 PM
nismax1994's Avatar
With the gxe fogs you will get lense+reflector. They are not like se at all. Even the Bosch seemed cheapo compared to the heavy se assembly. They have a metal spring/tab holding the lense on as well as very different mounts. I just ordered some no name ones from amazon. I will share pics when they arrive. I like the smaller size of the gxe fogs.
