Lowest I can go on +30 offset wheels (18X8 225/40 series tires) before rubbing....
Old Jan 17, 2008 | 01:10 PM
ohannon7's Avatar
Right now I have stock suspension, I wanna know how far down I can go before it rubs, or will it at all? Thanks
350Z 18" 6spoke wheels, +30 offset, 225/40/18 tires....
Old Jan 18, 2008 | 05:15 PM
ohannon7's Avatar
no one is running these 350Z wheels, or any other +30 wheel?
Old Jan 18, 2008 | 05:31 PM
SoonerFan's Avatar
Cletus
there is a wheel sub-forum
and a stickie in here with wheel specs
Old Jan 19, 2008 | 08:06 PM
Jcali2121's Avatar
yeah man, i'm rolling on 20's and i have no problems....you needa get smaller tires man
Old Jan 20, 2008 | 07:52 AM
ohannon7's Avatar
What are you talking about? I have 225/40 series tires on there?
Old Jan 20, 2008 | 08:37 AM
BLACKonBLACK98's Avatar
Former Vendor
i don't know a lot about the z wheels, but unless the are poking out you should be able to go as low as you want with a roll and the right size tire (225/40 will do).
Old Jan 20, 2008 | 10:46 AM
NmexMAX's Avatar
dot dot dot ...
I’m sitting on an Stech drop and +18mm.
Old Jan 20, 2008 | 12:18 PM
ohannon7's Avatar
wow, more info please
rolled fender? pulled fenders? tires size? what dimension of the rim, height & width? Thanks!!!
Old Jan 20, 2008 | 01:30 PM
NmexMAX's Avatar
dot dot dot ...
245-40-18, 18x8.5, small amount of rubbing on the passenger side, probably because I need to recenter my rear beam.
Old Jan 20, 2008 | 02:31 PM
Former Vendor
width and car model make a lot of difference.
Old Jan 20, 2008 | 04:41 PM
NmexMAX's Avatar
dot dot dot ...
Not when dealing with 4th & 5th gens.
Old Jan 20, 2008 | 06:03 PM
Former Vendor
you've got a good few mm more to play with. if i was on an 8.5 it would be like having a 23 offset. 5 more mm and i would be poking. granted we're talking mm, but thats what it boils down to.
Old Jan 21, 2008 | 04:18 AM
ohannon7's Avatar
thanks for everyones input!!
Old Jan 22, 2008 | 11:55 AM
Fast1one's Avatar
5th gens have a little more clearence, no?
Old Jan 24, 2008 | 08:24 AM
NmexMAX's Avatar
dot dot dot ...
Very little ...
Old Jan 28, 2008 | 08:07 AM
phatboislim's Avatar
i'm contemplating running +35offset wheels with 18x8 and 18x9s...i know this will work at stock height..but with like a 1.5-1.7 drop this should still work and not rub on my 00 right?
Old Jan 29, 2008 | 05:55 AM
anyone w/ info
Old Jan 29, 2008 | 06:48 AM
NmexMAX's Avatar
dot dot dot ...
Practice what you preach:
http://forums.maxima.org/showpost.ph...postcount=4777
anyone w/ info
Read between the lines, do the math.
http://forums.maxima.org/showpost.ph...06&postcount=7
http://forums.maxima.org/showpost.ph...94&postcount=9
Both taken from this very thread. Now plug your #'s into that equation and see what you get. i.e. your offset - mine, then add a about 1/4" to each side in order to compensate for the extra 1/2" width you will have on me (9" vs 8.5"). Convert those #'s to mm, and you have an idea as to where you stand compared to me.
Old Jan 29, 2008 | 06:52 AM
ohannon7's Avatar
your like a post sniper, very sneaky
side note: just read up on the re-centering of the rear beam due to passenger side rubbing, good info!!
Old Jan 29, 2008 | 01:45 PM
so i'll be fine then cuz mine will sit in more. thanks. i'm just trying to make sure
RinconI30
Nov 10, 2015 10:55 PM
alahjahwan09
18
Sep 21, 2015 09:12 PM
I<3 A32's
Sep 10, 2015 11:07 AM
dcam0326
Sep 8, 2015 11:02 PM
jfl330
Sep 4, 2015 01:44 PM
