will these fit?
Old Jan 21, 2008 | 09:50 PM
6thGenSmoke's Avatar
will these fit?
im looking into getting some 5 zigen gn and i was wondering if they would fit on my 6th gen? the size is: 18x8.5 and 18x9.5. i know i should be ok with the 18 x 8.5 but im just wondering if i will have any problems with the 18 x 9.5 rubbing. my car is not lowered but i may lower it in the future. also what size tires should i be running for both those sizes? thanks in advance
Old Jan 22, 2008 | 07:13 PM
the offset on the front are 48 and the rear are 43
Old Jan 22, 2008 | 07:49 PM
Fast1one's Avatar
Offset is way too high, 6th gens have more room then us 4th gens I believe so they would be sunken in, don't bother.....
Old Jan 22, 2008 | 11:38 PM
00SEMAX19's Avatar
Yes, they will fit.
Old Jan 24, 2008 | 01:07 PM
NmexMAX's Avatar
dot dot dot ...
Originally Posted by 00SEMAX19
Yes, they will fit.
Are you sure about that?
My guess is that they may be flirting with the strut. One way to do it is to get your stock offset/width #'s, and plug them (stock offset and width values) into the offset calculator located in the sticky on the top of this sub forum page, THEN, plug in the new wheel stats and see what values show up for clearance. THEN go get some actual measurements (distance forms strut to tire/wheel) and see if the numbers add up(i.e. verify that you will have enough room). My guess would be that that the rear is too wide and the offset is a bit high, which may cause it(tire) to rub on the strut. Better safe than sorry.
Old Jan 24, 2008 | 03:33 PM
00SEMAX19's Avatar
I'm pretty sure. I thought about that after I posted though. I believe on the 6th gen's there is more room away from the strut because of there independent suspention. Even if it does fit it is deffinately not a reccomended size for the car. Will not look good
+1 to checking the offset calculator.
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Pied
Sep 26, 2015 03:29 PM
