ignition switch cause long starts?
lately my 96 is taking longer to start after it sits for a while, like in the morning when i go to work and evening when going home. it would crank for upwards of 2-3 seconds before it starts. it has no problem starting after its already been driving, only when it sits for a long period of time. sometimes its rather embarassing. i'm buying parts for the 60k tuneup and am wondering if i should pick up a new ignition switch. i already replaced the fuel pump with a walbro unit few months ago. the starter was replaced about 3 years ago and it passed autozone's bench test when i brought it in few months ago. the crank position sensor is rather expensive so i plan to clean it before buying a new one. i will replace the plugs when i do the tuneup. i have about 25k miles on the copper plugs that are currently in the motor.
can anybody tell me what else might be the cause of my long starts?
thanks
thanks
Search around and there are literally thousands of threads about long (as well as hard) starting conditions.
Ignition switch IME isn't really a likely culprit, mostly what you see with a bad one is that it will intermittently lose connection, and you won't be able to start.
there were two instances in the last 5-6 months where i turned off the car to go to a store or something, then later returned and it will not start or crank or click or anything. i would turn the key, the dash lights would go off for a split second and immediately turn back on, but the car would no start. then after a while, maybe around 15-20 minutes of panicking and kept trying the key, opening the hood and fuse boxes and other random acts of desperation, it would start up as if nothing was wrong.
Kind of an off topic question, but i see that pic you posted about the OBD scanners I was wondering if you can do a paper clip method in the 95's and ground to contacts to make it spit out codes(they do that in fords). I'll search but this happened to be an opportunity while I was thinking of it.
Hey pmohr
For ABS codes, paper clip works. Not for DTCs. http://forums.maxima.org/showthread.php?t=76800
Update, after changing the ignition coil, fuel filter, fuel pump, and spark plugs throughout the past couple of months, the random long start problem still remains. If I park at work in the morning, then start the car at lunch time, it would take longer to start than normal. Then after lunch, on the way back to work, it starts right up, within fractions of a second, whereas before it would crank for 2 – 3 seconds before it fires up.
What else should I look at, on my list for this weekend is to clean and test the crankshaft position sensors. Other than that I’m not sure what else to do. Please advise.
Do you have an alarm. Even if you dont, you should locate the plug harness under the stearing column and using a test light, locate the wire that turns hot when key is in cranking position. simply run a wire from this harness "starter" wire to the starter coil. you will have to cut the plug because the coil wire is short. good luck...
tsi6001
Oct 3, 2022 10:23 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
shaunkey1
Aug 18, 2015 10:09 PM
