Truax SFC finally installed!!
Old Feb 18, 2008 | 09:21 AM
n3985's Avatar
大陆弟弟
Finally got he SFCs installed at ATX Motorsports in Bergenfield, NJ. For all the locals, great shop! They do everything from body to fabrication!
During the install they said one of the rails was bent. Probably from manufacturing after Truax did the tac weld, and when they went to weld everything else the welding pulls on the metal and thus was bent?
So with the rail straightened out, everything went on smooth. The installer also recommended that the center brace be welded to the factory brace for extra rigidity. I said why not since everything is still removable.
Pic below of what I'm talking about. Black piece is factory, gray primered piece is the Truax center brace..
First drive home = what everyone said, car feels much firmer over bumps, and as close to a BMW as you can get
Old Feb 18, 2008 | 09:27 AM
Colonel's Avatar
Old Fuddy Duddy
I had heard that Truax was redesigning these to get around that issue you mentioned. Have you had these a while awaiting installation?
Old Feb 18, 2008 | 09:29 AM
n3985's Avatar
大陆弟弟
Have had it since November haha, didn't have time or found a shop willing to do install.
Old Feb 18, 2008 | 09:49 AM
burnurass's Avatar
How much did they charge you? I've got a set still sitting around since when they first came out.
Old Feb 18, 2008 | 09:51 AM
n3985's Avatar
大陆弟弟
$240 total, with the extra bit of welding, priming the welds, and spraying the entire thing with rubberized undercoating.
Their # is 201-385-1003, ask for Narvin.
Old Feb 18, 2008 | 11:15 AM
Armon's Avatar
SFCs FTW
I just have the side rails, and not the cross member, but it still made a huge difference. Cost me <$100 to have a muffler shop weld it on. Since it wasn't a performance shop, I had to show the guy how to orient it and where to weld.
If I had to do it all over again with a stock car, this would be my first mod
Old Feb 18, 2008 | 12:03 PM
Colonel's Avatar
Old Fuddy Duddy
Thats what I keep hearing. Thats why I am waiting to see about a set that installs well.
Old Feb 18, 2008 | 12:19 PM
n3985's Avatar
大陆弟弟
Installs well? After the rail was straightened the installer even said the set was designed very well and everything fit perfect. If you take your set to a shop that cannot even straighten out a bar then I don't think you should be installing there
Old Feb 18, 2008 | 12:45 PM
irish44j's Avatar
retired moderator
the difficult part about the installs is that the car's unibody rails aren't necessarily straight either. I know one of mine was slightly bent so they had to alter the truax rail to fit it better...
Old Feb 18, 2008 | 01:58 PM
Colonel's Avatar
Old Fuddy Duddy
I wholeheartedly agree with you. I do all my car work.
But when it comes to welding I dont know that at all and cant do it. When I dont know how to do something, I become extra paranoid because I cant talk detailed enough to keep them from pulling something over on me.
Old Feb 18, 2008 | 03:00 PM
wyche89's Avatar
I'm thinking about getting SFCs as well.. did it do anything for your cornering stability? how about the the car losing composure when hitting bumbs going around a bend? did it do anything for any interior squeaks, rattles, or other noises you may have had?
Old Feb 18, 2008 | 03:01 PM
Prophecy99's Avatar
sick main.....looks great..definately wrote that # down
Old Feb 18, 2008 | 03:02 PM
n3985's Avatar
大陆弟弟
The car feels more stable going over bumps, doesn't shake around any more. Cornering? Don't feel much difference. Didn't have rattles to begin with so no improvement there.
Old Feb 19, 2008 | 06:28 PM
cefiro80's Avatar
That is the cheapest set of SFC I have heard on here. Congrads and glad you like them.
Old Feb 19, 2008 | 07:30 PM
L.M.L.
i guess i will not belive what people say about these things until i try it myself...
Old Feb 19, 2008 | 07:32 PM
wyche89's Avatar
do it... we could all use one more positive review that will push us to get these things ourselves!
Old Feb 20, 2008 | 07:34 AM
n3985's Avatar
大陆弟弟
I don't know if this observation makes sense, but driving around more last night, the car's "belly" feels heavier and more planted when making fast turns. Makes some sense to me as the SFCs added approx. 40lbs of weight.
Old Feb 20, 2008 | 07:40 AM
dineth00i30's Avatar
where can i order a set? or at least whats sfc stands for. my car feels awfully loose over bumps and i seriously need to stiffen up the ride and the chasi or my struts are blown i dont know but still tell me where to get these.
Old Feb 20, 2008 | 08:04 AM
'02_EMILBUS's Avatar
http://truaxmotorsports.com/products/
Im considering these from the positive review. I'm on Tein SS coilovers which is impressive.. but i have the rattles and could always use a more solid, firm, ride.
n3985: did you get the full bracing (Side rails/crossmembers) for 325 or the other option for 225??
Old Feb 20, 2008 | 08:12 AM
n3985's Avatar
大陆弟弟
I bought the whole set, side rails and center brace for IIRC $290 shipped during a group buy. But now it's $245 shipped in the GB section
Old Feb 20, 2008 | 09:14 AM
do you happen to have a link for that?? would appreciate it, i couldnt locate...
Old Feb 20, 2008 | 09:47 AM
Puppetmaster's Avatar
Dude, it is less than half way down on the first page of the GD forum:
http://forums.maxima.org/showthread.php?t=546291
Old Feb 20, 2008 | 09:48 AM
Me too, but think of it as helping create the initial demand. Thanks for the review.
I just need to get mine installed now after a year of them sitting in the garage.
Old Feb 20, 2008 | 09:57 AM
Prophecy99's Avatar
considering...where I am with my set up...I mind as well ...just spend a fraction more for these. The only thing that held me back was the quoted install cost of variying shops...$300~$600..but the quote from n3985 especially with the shop doing the rubber UNDER COATING! ...makes me way more motivated...I am going to call CSE engineering to and see what they will quote...to compare.
Old Feb 20, 2008 | 10:20 AM
Armon's Avatar
SFC = Sub Frame Connectors
You can buy a can of spray on rubberized coating for less than 10 bucks. Call around to your local muffler shops and find one that will charge $100-$200 for the install. (those are the prices out here, anyway)
Old Feb 20, 2008 | 10:23 AM
n3985's Avatar
大陆弟弟
I also recommend spening $5 and buying a can of primer, so you can primer all the rails before install. Then take remaining, prime the welds again. Followed lastly by rubber undercoating which as stated is only $5-10.
Old Feb 20, 2008 | 01:47 PM
OOmaxSE's Avatar
If memory serves, I think they are all primed when shipped out now... which is a pure bonus.
From looking at the pics OP, it seems like your car is on a 2-post lift. Is this correct?
Old Feb 20, 2008 | 02:05 PM
n3985's Avatar
大陆弟弟
4 post lift.
Old Feb 20, 2008 | 02:33 PM
sorry dood.... looked right over it.
Old Feb 20, 2008 | 03:45 PM
Prophecy99's Avatar
maybe i interpreted that wrong..
burnurass= How much did they charge you?
n3985= $240 total, with the extra bit of welding, priming the welds, and spraying the entire thing with rubberized undercoating.
from reading that it reads like the shop did all of the above..though I figured a shop typically wouldnt do that extra spray stuff.
Old Feb 20, 2008 | 04:19 PM
burnurass's Avatar
lets go...group deal! 200 each car.
The Law's Avatar
I R The Law
I've had the SFCs on for 5+ months. I love em, the car feels a lot better with them on.
Old Feb 20, 2008 | 05:00 PM
wyche89's Avatar
what differences did you feel in the way your car drives?
Old Feb 20, 2008 | 05:05 PM
Plenty of reviews here too:
http://forums.maxima.org/showthread.php?t=403280
Old Feb 20, 2008 | 05:47 PM
wyche89's Avatar
cool.. nice reviews... thanx puppetmaster
Old Feb 21, 2008 | 12:45 AM
gxe2se's Avatar
hey nan,
congrats on the install. Im glad it worked out for you.
Anyways, the price you quoted was on point when i got a
quote there too.
I'm still debating on the adding the SFC... mayb ill do it when im
back in the states.
As for the group deal... burnurass let me know if your gonna get it
installed. Mayb we can get install at the same time for discount.
-Anthony
Old Feb 21, 2008 | 07:05 AM
burnurass's Avatar
Originally Posted by gxe2se
hey nan,
quote there too.
back in the states.
-Anthony
When will you be back? I have them ready to go...they're just sitting in my basement. If we have a definate date maybe we can have Puppetmaster Join us for the group deal..he's asina and likes good deals too.
Old Feb 21, 2008 | 07:35 PM
gxe2se's Avatar
... I wont be back till Mid March.... I still have to order mine anyways.
Hmmmmmm tempting.
-Anthony
PS. I'll PM you when I buy.
Old Feb 22, 2008 | 05:34 AM
burnurass's Avatar
Hmmmmmm tempting.
-Anthony
Alright cool...i'll probably still be slacking by then
Old Feb 23, 2008 | 03:12 PM
ColdSHO's Avatar
if ur thinking about getting these read the reviews, i absolutelty love mine. if ur a suspension junkie you just have to have them hands down. perhaps not a word of difference, but deff noticable.
mine went on pretty easily, little bending but nothing drastic.
9aj9
Apr 5, 2020 12:11 AM
Mar 12, 2020 12:06 AM
MaxLife17
Jun 27, 2019 01:37 PM
lowpost99
Sep 8, 2015 05:06 AM
Johnny9595
Sep 3, 2015 05:18 AM
