please help, i might be screwed!
Ok i'm working on stuff on my 1997 maxima SE and one of the things we were working on was the mod to always have your cruise control toggle switch on. Well we took off the cap and used the wire to put in the relay and it didn't work. But the worst part about it was when we put it all back together, not only did the cruise control not work, but it wont even turn on and the power windows don't work and the power sunroof don't work. We used a fuse detector and so far all of them are good. Any suggestions of what might of gone wrong and/or what I can do to fix this problem. this sucks!
Thanks,
Scott
Thanks,
Scott
Thanks,
Scott
Thanks,
Scott
What terminals did you wire up when you tried the mod?
you are the man! Thank you very much. We used a fuse tester on all the fuses and apparently that fuse tester sucks because we tested that fuse #12 and it showed it was good, we took it out and the fuse was toast, replaced the fuse and bam, it worked! Thank you very much for you help. I love this club!
jchronis2552
Sep 23, 2015 04:57 PM
imported_Nismo_max
Sep 21, 2015 07:24 PM
