Time for the blackout(non-alcohol related) - Black Carpet, Dyed Headliner and pillers
Well, After checking out some websites with custom-molded carpet for our gen and realizing it was out of my price range, I called around to my junkyard.
Researching to find that NO 4th gen has black carpet or headliner....
I found this carpet in a 96 as well as two 5spd shifter trims.... I couldnt believe it. It was obviously aftermarket since the max had tan interior. I gutted the interior in about 30 min with a 14mm, 10mm and a phillips screwdriver. I was able to gut it so quick since I didnt care about any of the other interior pieces.
Total it was 10 14mm bolts (8 for seats/2 for seatbelts) 4 screws in the armrest and one 10mm bolt under the gas pedal.
The carpet was wet onone side from a broken window but I could tell it had not been there long...the rain was probably recent. Carpet smells decent and looks like it didnt see a lot of wear. I'm so happy!
It takes some work, but worth it in the end...
I got a graphite carpet. I've since done a black/graphite leather swap, so it all matched now
I also added some new sound deadening while the carpet was out. (2nd pic)
New Carpet
New Carpet
Damn, you made that look too easy...That looks amazing by the way.
I think I might look into the sound deadening department as well....How much a difference can you notice in cab noise reduction?
Hmmm, I didnt think it was that hard. A bit time consuming but I knocked it out in a day easily.
Should have just bought new carpet. Its not that expensive. Makes no sense to me to pull everrything out just to put in old carpet, even if it is a different color.
But seriously, those pictures don't do the carpet justice, my interior wil look sick with everything blacked out.
oh flava, btw, new molded carpet runs about 130 plus shipping....I got two 5 spd shifter trims and this carpet for $40....I think I did pretty well. The carpet will look like new once I have a decent day to put it in.
I'd like to see your dyed Headliner and pillars. I have a tan interior in my car and i truly hate it. It it looks nice dyed that would be cheaper than what i have in mind. Good job, but i think you should have thrown down at least a little sound deadening....it works wonders. I did my 3rd gen when i stripped it down..well worth it!
More than anything it's a bit time consuming but not that bad. i guess $40 wasn't to bad. I think I paid somewhere around 120 shipped for mine. You should also finish much faster since it's already pre-cut. All you'll have to do is lay it down......Nonetheless it will be worth it at the end.
Can you show the dye job of the pillars/headliner? Do you have I30 pillars? What are you going to do about the un-dye-able plastic pieces in the ceiling?
What do you mean NO 4th gen has black carpet? Are you saying that because the black interior Maximas really have more of a gray carpet?
As for the headliner, I have not completed it yet since its been raining the last 2 days. I'm kind of screwed because my spring break is over already so I'm going to probably have to wait a week to drop it out and spray it.
I just have stock maxima pillars, they're grey. I think I'm going to use Krylon Fusion Plastic spray paint for the pillars and then lay down some clear on top. If I use Krylon Fusion, I don't think I'd have to use an adhesion promoter! As for the plastic pieces on the ceiling, (i.e. oh **** handles, dome light, etc.) I think I'm going to try to paint those as well.
Yeah, I meant that NO 4h gen from factory has straight black carpet, they are all grey color. This carpet I bought is dark black.
When you say 'spray it', what method/product do you use to dye the headliner? I just figured you'd mix up a bucket of Ritz and sponge it on. Shows how much I know, lol. So how do you 'spray' it?
Let us know how it comes out.
Yeah, stock carpet is nasty. I can't wait until everything is black.
That dye you used is called Rit. I have a pack of black at my house I never used, how well did that work for you? Was it had to work with?
Anyway, I've seen some write-ups on other sites using Duplicolor Vinyl and Fabric Paint. It looks nice for headliners especially. Here's a picture of what the cans look like:
This seems to be a much easier way to dye it since its just aerosol and not messing with mixing up dye and the mess, etc.
Yes, Rit, excuse me. I think it came out o.k. It went on pretty well. I just used a bucket and sponge. And it is even. But I wouldn't call it pitch, pitch black.
Mmm, I hope that Fusion works for you. I have never had much luck painting plastic. Your other choice would be to get I30 pillars from a junk yard so you can dye the fabric.
Good luck.
Good luck.
You could replace the fabric on the headliner, or cover over it with some store bought material...
but that would only make sense if there was something wrong with the headliner.
My friend did his before (not a max, but still)
If it's just the color you want to change, then yea, dying would be the way to go.
I'm at college right now so I have not had anytime to continue working on my car. Hopefully this weekend I will get some good weather and be able to finish the inside and post some pics up for you guys.
I sprayed the headliner, rear shelf, and the whole trunk with the duplicolor fabric and vinyl paint. Every spec of dirt shows in the trunk now. The headliner and shelf look fine. It does rub off however. There is one spot where my sunvisor rubs on the headliner and its a lighter color.
have any of you guys used that Vinyl color spay on the OEM floor mats? pics? I have the gray color carpet and one of my floor mats have a bleach stain on it and was thinking about dying it with sponge method till I heard about this spray.
You make it look so easy...!
