6th Gen Trans In 5.5th Gen?
Has this been done before? My transmission is...well...5.5th gened and I plan on getting a new transmission. Its cheaper than getting a new car, plus I figure I can get another 80-90k out of a new trans. The engine is good, no problems (knock on wood) but will the 6th gen 5 speed trans just bolt right up to the 5.5th gen? I know i will probably need to get new TCM but anything else?
Are you refering to the 5 speed auto or 6-speed manual? I know you said 5 speed but a lot of people call any manual transmission a 5-speed.
The manual tranny is a direct swap with no extra parts needed. I don't know about the auto.
For what, the 5AT or the 6MT? For the 5AT (I don't believe anyone has done that particular swap yet) you would likely need an A34 ECU, TCM, possibly a new mount, who knows what else. Shifter assembly, cable and all that probably.
Prices will be different for pretty much everyone. Price out a trans, trans mount, shifter + cables, flywheel, clutch, clutch pedal, master/slave, etc. Then, labor. Doing it yourself?
I see your text regarding 6sp being a direct bolt up to 5sp MT on 4h gen.
Have a trany guy that is searching for more info on this swap.
Can you by chance say where more info on this swap might be located.
Thank you.
ShopFixDIY
Thank you.
ShopFixDIY
Max139617
Sep 20, 2015 07:09 PM
