Vibration on acceleration problem.
Old Mar 16, 2008 | 01:37 PM
skuccio's max's Avatar
Beast Mode!!!
I get a mean shudder in 3rd gear from maybe 2-4K. It started after I lowered my front end about an inch more with my coilovers.
I haven't got my alignment yet so I'm thinking it's either that, an axle going or a motor mount; it seems most like a motor mount to me though as I had the same problem in my old Accord.
How can I diagnose the problem?
Old Mar 16, 2008 | 01:40 PM
njmaxseltd's Avatar
Axle / CV joint going bad. You lowered it, so the angle the CV joint is on has been altered or increased. If it's bad or going bad, your change in the operational angle will amplify it.
Old Mar 16, 2008 | 02:11 PM
martells2's Avatar
I agree, but take a look at the motor mounts anyway. This is similar to offroad vehicles that do a suspension lift and then blow u-joints/drive shafts. When you change the angle of the driveshaft or in your case axle shaft it puts more stress on it so if it were already starting to go out you would begin to notice it much quicker. good luck!
Old Mar 16, 2008 | 08:13 PM
Beast Mode!!!
I guess with lowering the axles are gonna be going regularly, as I changed both axles when I got my coilovers installed in November. The roads are really bad here so I could see how that would do it. Sucks
jmlee44
Oct 2, 2022 02:13 PM
user 11122324
42
Jul 18, 2022 03:35 PM
D Mason
Jun 21, 2016 04:43 AM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Need help
23
Oct 2, 2015 08:56 AM
