Removed antenna, keyless/clock/homelink dead.
I swapped the working antenna from my Max to the I30 only to find that the I30's plug was corroded and filled with water. Not thinking I cut the connector from the Max while the battery was STILL connected to make a pigtail to splice in. I did the same thing on the I30 but everything in that car works.
I have a feeling I may have fried the LCU for the keyless in the trunk or at least tripped the BCM with dead/no signal/error from that unit. The only items that do not work are the homelink, keyless (all functions), and clock. I would swap in the I30 LCU but I am afraid to fry that one as well. As it is now, I spliced the wires into the I30 plug (which was corroded but did not cause these problems on the I30) to complete the circut rather than terminate each wire.
The specific wires that were cut were on the antenna plug are:
-Black
-Black/Red tracer/small silver markings
-Pink
Thanks for any help!
-Black
-Pink
As far as finding what runs off of each # fuse (some are just labled "elec") did you use the FSM and what section? I looked through the EL section and had diagrams of the fusebox but no labels. Thanks again.
1st thing I checked when I got home and had that nice little burn and split fuse LOL. Appreciate it.
i too would like to know what each fuse is specifically for.also, it always is nice to find out you just blew a fuse when something doesnt work rather than finding out you fried something
my03maxima
Jul 28, 2024 07:40 AM
RealityCheck
Oct 2, 2015 06:34 PM
