Car shaking and CEL flashing?
hey guys, ive just had this problem, yesterday morning, my car started shaking when i started up the car and the cel started flashing not too long after that? i know the spark plugs hasnt been changed in about 5 years and the wires and distributor cap also, but could it be something else? where can i take the car to get it diagnosed without getting raped up the ***? thanks!
First, our cars dont have plug wires and distributors, they run off ignition coils controlled by the ECU. Second, how many miles are on the plugs? Plats are safely rated to 60K, but many people here and elsewhere i know have 100K+. Third, if I remember correctly, a flashing CEL is an engine misfire, so def. start with checking plugs, and if those are good, sounds like an ignition coil is bad.
autozone will read the code for free, but it sounds like a bad plug or coilpack. engine is missing and causing the "shaking" or hesitation feeling and the flashing cel means there is a big problem, like a complete non fire on a cylinder
most likely causes are:
Bad ignition coil(s)
Bad spark plug(s)
Failed fuel injector(s)
You can do the diagnosis on your own, it's very very easy.Start by pulling the code from your ECU. all you need is a flathead screwdriver and 45 seconds of your time. Instructions to do it can be found here:
http://forums.maxima.org/showthread.php?t=76800
Once you have the code and confirm that there is a misfire, you can look up the code in the link above and figure out which cylinder is misfiring. Standing in front of your car and looking into the engine bay, the cylinders are numbered like this:
1 3 5 (rear)
2 4 6 (front)
So, if you have a cylinder 4 misfire, for example, you should determine first if the cyl 4 coil is bad. If you need information on removing the coils, you can find detailed procedure in this spark plug removal thread on VQpower: http://www.vqpower.com/v2/readarticle.php?article_id=45
To check the cyl 4 coil, pull it out and shift it to cylinder 6. Put the cyl 6 coil into cylinder 4. Reset the ECU (again, follow the info in the sticky), and take the car for a drive. When the engine light comes back on, pull the code again and see if it has shifted to cylinder 6. If it has, then you've confirmed that that coil is the cause of your problem.
If the code stays at cylinder 4, then you should repeat the same procedure, but this time shift the cyl 4 spark plug to cyl 6. If the trouble code remains at cylinder 4, then the next step is to check and possibly replace that injector. But that procedure is a little more involved, so check the coils and plugs first and let us know what you find. If you determine that the injector needs to be replaced, we can help with that as well
Bad spark plug(s)
1 3 5 (rear)
2 4 6 (front)
what codes are you pulling .... if you're not having the codes read, you'll end up replacing everything except the problem! (just my look on it ... take it or leave it, trying to save you $$$)
Autozone will read the codes for you and tell you the problem
Lakersallday24
Jun 16, 2019 01:35 AM
ah2002
Mar 9, 2016 01:42 PM
Team STILLEN
Aug 10, 2015 04:29 PM
