Anyone have a clutch cylinder template for 5spd swap?
Hey everyone, Im about to start the 5spd swap and wanted to know if anyone had the clutch template (for making holes in the firewall). I don't have a parts car (got all the parts from yard) so it'd help a bit if someone had one that they could scan.
can't you go back and find the parts car at the yard and just get it from there? if i had mine still i would give it to you but then again i don't have a scanner. don't know if anyone else on here might still have theirs?
Yes it did, thank you much
I doubt the car is still there, I pulled the tranny off quite a while ago..
Wish I had one at the time I did my swap. I just estimated, then reamed the holes out with a dremel for proper alignment and fitment, siliconed up the edges and used stacks of washers on the clutch pedal assembly studs in lieu of the OEM spacer...Hey, when you don't have parts available to you, you do what you have to to make it work...Still gets the job done 2 years later...
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
knight_yyz
Nov 1, 2015 01:34 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
