5th gen: AMP power wire, WHERE???
Old Mar 27, 2008 | 09:24 PM
borka's Avatar
Please help me out, i am trying to run my power wire from the battery to the trunk, and i can figure out for the life of me where can i get it though the firewall ???? i looked everywhere and there is no hole.
Old Mar 28, 2008 | 05:45 AM
burnurass's Avatar
Take off the driver front wheel (after you have jacked it up of course) and take off the fender liner. You should see a wiring harness that you can follow from the engine bay to the interior.
Old Mar 28, 2008 | 06:17 AM
borka's Avatar
Thanks, yeah i saw that hole , there is an engine harness that goes inside, but i couldnt find where it went on the inside. i guess i will give it another shot.
the hole im talking about is when u remove the fenderwell trim, the engine harness goes into it and next to it the hood release cable is also.
I found the hood release cable on the inside, but the engine harness wasnt next to it.
Old Apr 3, 2008 | 08:23 AM
shorterthanrich's Avatar
You can go that way...or you can use a drill and a unibit to drill the correct size hole through the firewall. thats what I did - not too difficult. just surround it with putty or a grommet when its all in place.
there are also already some holes that run other wires and have a rubber grommet. you can cut a bigger hole in the grommet and fit your power wire
lowpost99
Oct 26, 2025 06:53 PM
wyobbagy
Jan 3, 2023 12:03 PM
MAXSE5SPD
Sep 17, 2022 04:00 AM
The Frye
Sep 2, 2021 11:03 AM
