FS: JL Audio 300/4 Four channel amp
Like the title says, I am selling a JL Audio 300/4 amp. I no longer need this amp. I am looking to get $200 OBO shipped for the amp. Here's a pic of the amp. It has a few blemishes but if I were to rate the amp cosmetically I would give it an 8.75/10 but judge it for yourself.
Here are the specs:
Rated Power (4 Channel Mode): 75 W RMS x 4 @ 1.5 ohm-4 ohm (11V-14.5V)
Rated Power (Bridged to 2 Channel): 150 W RMS x 2 @ 3 ohm-8 ohm (11V-14.5V)
THD at Rated Power: <0.03% @ 4 ohm per ch.
S/N Ratio: >108.5 dB below rated power (A-weighted, 20 Hz - 20 kHz noise bandwidth)
Frequency Response: 5 Hz - 30 kHz (+0, -1dB)
Damping Factor: >200 @ 4 ohm per ch. / 50 Hz
>100 @ 2 ohm per ch. / 50 Hz
Slew Rate: ±25 V / µS @ 4 ohm per ch.
Left to Right Channel Separation: >75 dB @ 1 kHz
Input Range: Switchable from 200mV-2V RMS to 800mV-8V RMS
Dimensions (L x W x H): 13.40 in. x 9.25 in. x 2.36 in.
340 mm x 235 mm x 60 mm
As with all electronics, all sales are final!
Thanks,
Oliver
Here are the specs:
Thanks,
Oliver
popdedop
Sep 11, 2015 11:17 AM
