6th Gen Maxima Traps at 110MPH! 12.83ET My personal Best Ever!
I finally opened my Zex controller and cleaned the Nitrous and fuel filter as I suspected the nitrous filter was clogged and I made a change on one of the fitting and the end result was a beast coming out the hole spinning tires in 1st and second gear my first two passes sucked I ran a 13.5 and a 13.4. Needless to say I have to learn how to launch my car again so on my next three passes I feathered the throttle out the hole not my best 60' foot but my best Damn E.T. and Trap speed ever and I was still spinning out the hole on these three passes but not as bad as the previous two passes! So, once I get my launch back together I should good for a 12.6 or 12.7 pass.
1. 60' 2.108
E.T. 12.957
MPH 109.75
2. 60' 2.026
E.T. 12.970
MPH 109.05
3. 60' 2.039
E.T. 12.835
MPH 110.48
[/img]
1. 60' 2.108
E.T. 12.957
MPH 109.75
2. 60' 2.026
E.T. 12.970
MPH 109.05
3. 60' 2.039
E.T. 12.835
MPH 110.48
[/img]
congrats, glad to see someone got their problems worked out
I think thatr I solved my problem and will test it out tonight or tomorrow then hit the track next week hopefully I'll see you there
if you do not mind I'll vid your run so you can post it
(with my usual two stages of spray) Of course, the M&H slicks also do pretty well.
I dunno if these would help kevin007 - I never smoked tires like he does - of course, I haven't tracked my 3.5 yet, either. Maybe I can do that !!
Pictures help, anyway - and superlight 12" track slicks on superlight alloy wheels gotta be good, right?
I found that smoking them long actually hurts me because it is a drag and I think I'm causing a greasy like residue when I smoke im longer I've been smoking them for only two to three seconds and then dry hoping them and it seems like I been hooking a little better. Saves money also.
The Hoosiers are on M/T 15x10 - 13lbs each - 5 in backspace - rear-drive wheels. These suckars are light.
The M&H slicks are on Am. Racing 15x8 wheels - 4 1/2 " backspacing - rear-wheel drive as well.. They're around 18 lbs, I kinda remember.
Nice! Congrats on the times, Kevin. Any weight reduction done to your car? Just curious.
Btw, not sure if you remember, but I met you at the Pete Farrell dyno day, I was there with my son.
i love cecil county dragway on wednesday nights. thats where i ran my PB. you could make like 40 passes if you wanted to. they always prep the track really well too.
Congrats on the new PB!
Thanks! I remember you, full trim no weight reduction. I added lowering springs about a 3 weeks ago, they seem to help on my launch.
Lakersallday24
Nov 7, 2024 07:31 PM
morteljc
Oct 19, 2015 10:47 AM
