anyone ever break an abs brake line?
I was being impatient while removing an axle and ended up pulling too hard on the abs rubber brake line. I saw a little drop of fluid pour down from the protective sleeve so i'm assuming somewhere it has a little crack or hole. I cant seem to find a replacement for this on any of my usual part websites.
Anyone know where to get this? I'm going to check the dealership next.
Just be sure that its the ABS wire, it doesnt connect to the caliper, it connects to the Knuckle/hub assembly.
As stated that is the ABS sensor wire not the brake line, it connects to a harness just on the other side of that grommet IIRC. Fluid wouldn't have been from that, and as long as you have no ABS code you should be set.
whew. one less thing to replace
knight_yyz
Nov 1, 2015 01:34 PM
Need help
23
Oct 2, 2015 08:56 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
