maxima coilover kits??help
Old Apr 6, 2008 | 01:26 PM
mark_mck15's Avatar
i am in need of lowering my maxima and i have heard to use coilover. im a real newb when it comes to suspention ,but i know what coilovers are. to lower my max do i just need the coilover spring kit as sold on ebay for like175? will those do the job right?is that all ill need? ups and downs on just the spring kit?
thx
Old Apr 6, 2008 | 02:16 PM
garyrr's Avatar
1st off u need to deside how much you want to lower your car. spring kits lower your car 1.5-2 inches and are not adjustable. they will feel more comfortable( compared to coilovers) because the spring isnt as small and stiff so it can reduce the bumps better. DO NOT just buy a lowering spring and put it on ur stock shock. stock shocks are not designed to work with stiffer spring and most ppl have problems within the 1st 6 months. also your stock strut being 10 years old will be pretty worn already. If you want a realy agressive drop (2-5 inches) you will need coilovers. the main barnds are tein, k sport, and dc ( i think, itsbeen a while since i bought my setup) they each have their own benefits but k sport is the only one with camber adjustetment built in( no need to buy an aftermaket kit. Remember that having coilovers will be a very harsh ride and you should probably think about the area you drive because every bump will feel alot worse on coilovers.
there is more info in the stickies im pretty sure and expect to pay 800-1500 for coilovers and about 400-600 for spring strut combo
Old Apr 6, 2008 | 02:19 PM
maxboy325's Avatar
I wouldnt use a cheapy Coilover kit like that check classified section there are a couple of kits for sale
Old Apr 6, 2008 | 02:36 PM
KyleFort32's Avatar
so u guys are saying for a nice drop and comfortable ride use springs?
Old Apr 6, 2008 | 02:41 PM
garyrr's Avatar
yes, i have k sports for the summer. they are actualy going on in 2 days again( winter sucks) but after this year im going to prbably trade them for spring strut comb because the ride is realy bad. but it handles better and looks so much sexier with a 4 inch drop.
Old Apr 6, 2008 | 03:18 PM
LeVeL's Avatar
for a nice drop and comfortable ride go the ghetto route and cut your springs. seriously, if youre not looking for any performance gains then this is the cheapest way to drop the car and the ride will be close to stock
Old Apr 6, 2008 | 03:39 PM
mark_mck15's Avatar
ive also considered that, but i cant find one person to tell me the procedure to do this?...can you give me the full details
Old Apr 6, 2008 | 04:37 PM
LeVeL's Avatar
As far as I know you just take the old springs out, cut them, and put them back in... just make sure you cut em all by the same amount lol
Old Apr 6, 2008 | 06:20 PM
Flava_24/7's Avatar
Boosted Panda
My Tein Basics actually ride much nicer then my previous Spring/shock setup.
AGX's and Illuminas have damper adjustments, so the firmness of the ride can be adjusted.
Old Apr 6, 2008 | 06:21 PM
Flava_24/7's Avatar
Boosted Panda
Worst idea ever!
The Ride will be horrible with cut springs.
Old Apr 6, 2008 | 10:42 PM
Nissan 6's Avatar
sarcasm..
Old Apr 6, 2008 | 10:47 PM
maximaSE327's Avatar
i also have the tein basics and i love the ride... handles like im riding on rails. i have gotten many compliments from other people driving my car
Old Apr 7, 2008 | 12:24 PM
Snypa's Avatar
Worst idea ever!
agreez ^^^
Old Apr 7, 2008 | 12:39 PM
Slickismax's Avatar
With Ground Control you can specify the spring rates when you order them.
Old Apr 7, 2008 | 12:41 PM
95MaximaDriver's Avatar
If your looking for a good coilover set up i would go with the Ksport Coilover kit...yeah its a little pricey but i personally love the adjustability factor that they have you can fine tune it to your driving needs and wants..with the coilovers dont go the cheap way out because you will spend more money replacing damaged parts. i personally ride on the Kspors..it has a nice solid feel on the road.
Old Apr 7, 2008 | 03:32 PM
garyrr's Avatar
yes you can change the spring rate. you can also do this with k sport. but if i rode on any softer springs i would bottom out after every bump. when u ride that close to the ground u deffinatley dont want soft springs
just throw some dee's on that *****. that will get rid of ur wheel gap
Old Apr 7, 2008 | 07:24 PM
mark_mck15's Avatar
any links to the kits?
Old Apr 7, 2008 | 07:51 PM
Flava_24/7's Avatar
Boosted Panda
Ive heard too many horror stories and not just from maxima owners about K sports continously blowing there struts .
Old Apr 8, 2008 | 07:32 AM
97SMG's Avatar
^^ Ksport suck big time. I bought a set to only have them on for no more than 3 months. If you have cold a$$ winters be ready to have a winter setup because more than likely they will not make it through the entire season. K Sport = FTL
Old Apr 8, 2008 | 09:20 AM
i am going to reiterate the quality of the teins... i bought them in 05 and they have been on my car ever since, been through 3 massachusetts winters and taken the beating of boston roads, and they STILL drive like the day i bought them... best investment i made for my car, HANDS DOWN!
Old Apr 8, 2008 | 03:18 PM
Bonka's Avatar
Schnell kaputt
I don't know why adjustability is such a big selling feature for people. Most coilover users get them for looks. Most of them likely do not know how to properly adjust the dampening settings anyway and even if they did few would adjust the settings other than the initial fine tuning.
I would just get a simple system that only has height adjustment. Progress, Tein or GC w/ the modified Koni's are more than enough for 98% of Maxima owners.
Old Apr 11, 2008 | 01:12 AM
KJS2023's Avatar
I ended up getting a set of Eibach lowering springs that can be adjusted from stock to 3 inches. This way I can raise it back to normal in the winter and lower it in the summer. Connecticut sucks in the winter time.
Old Apr 11, 2008 | 06:16 AM
Flava_24/7's Avatar
Boosted Panda
Sounds like you went with Ground Controls then. What struts are you going to pair them up with?
Old Apr 11, 2008 | 07:14 AM
Digitized's Avatar
I got D2's.. gonna be the 4th summer I have them..
no issues here... I take them off for winter( stock set up in winter)..
every spring, I give them a nice cleaning before re-installing them..
D2's offer the same dampening adjustment ( 36 way) as the K-sports and have camber plates built on so you can adjust your camber in the front..
I've read a lot of people have had issues with D2's/K-sports, but personnaly, I haven't and I run with a 3-4" drop...
I would either get spring/strut combo or Coilovers.. don't waste your money on coil over Kits...
Old Apr 11, 2008 | 12:16 PM
KJS2023's Avatar
i have kyb gr2 which is more of a oem replacment but they work great. The springs I have though have to be lowered manualy they arent the style where you have a control inside of your car. SO once a year I just have to go out jack it up and screw it up in the winter and down in the summer.
Old Apr 11, 2008 | 12:20 PM
Flava_24/7's Avatar
Boosted Panda
So you do have Ground Controls. I dont see how the GR2's last with those unless you dont go too low with them. I wouldnt even expect them to last on a 2" drop.
BTW, the only suspension that would allow to to raise and lower inside the car would be an air or hydro setup.
Old Apr 11, 2008 | 12:25 PM
IlyaK's Avatar
The Golden One
You guys should join NYCMaximas (if you're local I guess) and read the sticky/thread that K3Y typed on showing pro's and con's of like 10 different kits.
Old Apr 11, 2008 | 06:58 PM
hazardous's Avatar
I agree. It's very informative
Old Apr 25, 2008 | 09:58 AM
only4mal's Avatar
Front is higher after lowering
Question:
I bought the lowering springs and had them installed...I have a 98 Max, I didn't replace the shocks, because I didn't know any better, I noticed the back sits lower than the front. Will new shocks solve this? And if I replace the rear shocks, do the fronts need to be replaced as well? they seem to be holding up better than the rear.
Last edited by only4mal; Apr 25, 2008 at 10:09 AM. Reason: clearer explanation of question
Old Apr 25, 2008 | 10:17 AM
Flava_24/7's Avatar
Boosted Panda
Originally Posted by only4mal
Question:
No, replacing the shocks isnt going to change the ride height.
What springs did you get? Some springs are known to have saggy rears.
BTW, yes you should replace all four shocks/struts.
Old Apr 25, 2008 | 10:30 AM
only4mal's Avatar
What springs would you recommend for an even drop?
Old Apr 25, 2008 | 11:09 AM
Flava_24/7's Avatar
Boosted Panda
It all depends on how low you wish to go really.
In reality, if your going to go with new springs and new struts you may want to consider the coilovers.
If I knew then what I know now I wouldve done that setup to begin with.
Old Apr 25, 2008 | 11:35 AM
only4mal's Avatar
I only lowered it 1 inch, thats low enough for me on the roads around here.
Old Apr 25, 2008 | 11:55 AM
only4mal's Avatar
I was also told that over time it would settle and possibley even out, that doesn't make sence to me. Anybody know different?
Old Apr 25, 2008 | 12:55 PM
DomoMaxima98's Avatar
Do u have a manual or automatic? do u have a sub or other items in your trunk?
Old Apr 25, 2008 | 02:24 PM
only4mal's Avatar
[quote=DomoMaxima98;6377288]Do u have a manual or automatic? do u Manual
Old Apr 25, 2008 | 02:26 PM
only4mal's Avatar
A manual and nothing in the trunk but an empty toolbox and a bat...nothing with any weight
Lakersallday24
Nov 7, 2024 07:31 PM
SmokinMax02
18
Sep 11, 2015 12:25 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
