genral question about injectors
does the resistance really matter if the injector clicks? i guess what i am asking here is if the injector clicks should i even bother with testing the ohms?
It takes 30 seconds so I would do it anyway, personally.
Just remember that you're only testing the electrical capabilities of the injector, vs the physical; actually spraying the fuel, and doing so correctly.
well i did test all of them and all of them seem like they are out of spec. that is why i was wondering. some of them are consistant with others and some are totally diffrent. i know the fsm says like 13.5-17.5 @70f ohms(fbjc100) mine are like 40 or 50ohms @ room temp. so... maybe all of them are shot?
How can bad injectors destroy your computer?
your computer is designed to work with a specific resistance. when the resistance is off you start damaging circuits in the computer. I've seen it happen on cars before, then again I've seen just about everything.
jmlee44
Oct 2, 2022 02:13 PM
Unclejunebug
Apr 2, 2016 05:42 AM
