No Power to anything but starter and fuel pump.
Went to start car and Turned key on Battery light stayed on. Cranks fuel pump kicks on. But no juice to anything no horn or even radio. The car won't start at all. Could it be the ignition relay?
ECU is w/o power? Check the fusible links, ECU cont relay, fuses, then +12V pwr supply at ECU
see http://www.cardomain.com/ride/748507/5
"Turbo Still no start after months!!"
http://forums.maxima.org/showthread....238&highlight=
"#6 Injector dumping fuel when acc turned on"
http://forums.maxima.org/showthread....278&highlight=
"Need to find starter relay."
http://forums.maxima.org/showthread....980&highlight=
"Car won't rev over 2000rpms"
http://forums.maxima.org/showthread....163&highlight=
"My SAFCII is it fried?"
http://forums.maxima.org/showthread....974&highlight=
"Car running rich on startup"
http://forums.maxima.org/showthread....137&highlight=
"Bad knock sensor reading 86 at 1300rpms!"
http://forums.maxima.org/showthread....939&highlight=
"Boost gauge goes to 0 and stops also BOV not working."
http://forums.maxima.org/showthread....250&highlight=
[QUOTE=Maxpwer;6400872]No problems? Then why did you start all these threads in the past 3 months???
all of these threads I started were caused by the same problem relay went bad and created a short in the injector wiring. and none of you guys had any idea on what it could of been except say it was cause the setup if you think only wiring in it is in the SAFCII which was installed correctly. dumbass
i was going to dig through and find all these fine examples yesterday, but i fell asleep..
Forge277
Jun 13, 2016 09:26 PM
