? About Drives Axle and Trans.
Old May 13, 2008 | 07:10 PM
maxboy325's Avatar
We have tried just about everything and this DAMN DRIVER SIDE AXLE WONT BUDGE . I have searched and some say remove pass. side and knock it out with a screwdriver through the trans.; is this OK for 5speed? FSM say for Autos. Its only the half shaft thats stuck in the trans. the rest has come apart. Like I said above I have searched and it was unclear to me if the above method works for a 5speed( my friend thinks it wont fit all the way through). any and all comments are welcome THANKS TO ALL!
PS: THE CAR IS NOT ON A LIFT! (jack stands)
Old May 13, 2008 | 08:07 PM
maxboy325's Avatar
1st bump
Old May 13, 2008 | 09:13 PM
maxboy325's Avatar
2nd bump
Old May 13, 2008 | 10:05 PM
91parkave's Avatar
get nice 15'in+. prybar, problem solved
Old May 13, 2008 | 10:08 PM
maxboy325's Avatar
tried it wont move at all we used one that was about waste height
Old May 13, 2008 | 10:25 PM
Maxima_Joe's Avatar
4th Gen Parts King
Turn the axle a little and pry again. Keep doing this.
Old May 14, 2008 | 02:13 AM
KRRZ350's Avatar
There was a similiar thread a few weeks back about a guy who had two shops that gave him back his car saying they couldn't get it out, another guy chimed in where he actually had to pull the tranny off to get his little halfshaft remains out!!!!!!!!! That was last resort, attempt to bang it from the other side, however since you are open-dif you will need to use something narrow enough to slip past the spider gear pin and not damage it.
Old May 14, 2008 | 04:16 AM
maxboy325's Avatar
Yeah we have tried that also I guess I will have to keep at it until it pops out. We spent hours tryin to get it out!
Old May 14, 2008 | 04:18 AM
maxboy325's Avatar
How narrow are we talking here? Im not sure how much clearence I have to work with doing it this way.
Old May 14, 2008 | 04:25 AM
alset2's Avatar
Have you tried 2 prybars at the same time about 180 degs apart?
also try to slightly alternate your pressure back and forth between the two prybars. this usally works .
i have never heard of having to take an trans out to get an axle out and i have quite a bit of experience with Nissans.
also I am a little leary of saying this but I am sure you can use common sense and not break the trans case , but dont be afraid to apply some pressure if you know what I mean.
good luck
Old May 14, 2008 | 04:41 AM
maxboy325's Avatar
good luck
No I havent tried to prybars. We did pry and bang it at the same time though, and pressure was not an issuse I thought how we were going at it we would break through
Old May 14, 2008 | 07:05 AM
KRRZ350's Avatar
I think a really long 3/8"s extension clears, but don't quote me on that. Look in from the passanger side so you can see the big cylindrical peice that you must clear.
Old May 14, 2008 | 07:28 AM
maxboy325's Avatar
Ok, im gonna go back at it in a lil bit. I just cant believe it wont pop out! I had the clutch replaced in december so it had to come out; maybe just harder because were working on the ground
Old May 14, 2008 | 11:53 AM
imports_only1's Avatar
I just changed both my front axles a few days ago. I ran into similar problems. I used a ball-joint pry bar (looks like a tuning fork) and pound it with a huge hammer. Both axles came out with ease.
Old May 14, 2008 | 03:32 PM
nhaven's Avatar
To the op. Try using your foot to apply pressure to the end of the crowbar. Mine popped out with very little effort when I did it about a year ago using this method.
PH98I30
29
Feb 10, 2025 12:03 PM
boomerbrian
Oct 31, 2018 10:25 AM
captchaos
Mar 15, 2016 12:18 PM
FanaticMadMax
Sep 4, 2015 02:45 PM
